Xado™ MUST SEE!
Discussion in 'Off-Topic Discussion' started by neontrail, Sep 18, 2008.
  1. Sep 18, 2008 at 5:59 PM
    neontrail
    neontrail [OP] ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    http://www.xadousa.com/
    Friend of mine became the national distributor for this stuff.. It's pretty serious, and may make him mucho coin!
    What are your thoughts TW?
  2. Sep 18, 2008 at 6:08 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    so what do u do sell it and become a distibutor. like a fortune 500 thing??
  3. Sep 18, 2008 at 6:45 PM
    neontrail
    Idaho
    Yea, something like that I suppose.. I do know hes in the works with a major mail carrier. Tests have shown that they will SAVE HUNDREDS of MILLIONS yearly on their fleet vehicles with this product being used.
    From what I understand its just becoming available to the USA
  4. Sep 18, 2008 at 6:53 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    well if it will benefit the Economy and such, i think it would be great. i read about it. sounds really good. I wonder if there are stock options available??
  5. Sep 18, 2008 at 7:16 PM
    neontrail
    Idaho
    i will find out
  6. Sep 18, 2008 at 7:18 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    cool. send me a pm if they do. thanks
  7. Sep 18, 2008 at 7:29 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    So... just checking out their webpage... interesting stuff, would it void a warranty?
  8. Sep 18, 2008 at 8:01 PM
    neontrail
    Idaho
    i really have no idea
  9. Sep 18, 2008 at 8:09 PM
    Clelsdah
    Clelsdah Western Alliance: Yeehaw Division
    No California Foothills
    08 SR5 4x4
    Bed mat, tube steps, Ipod interface, Ride-rite air springs
    Can anyone say "snake oil"??? Sorry for the cynicism but with a flashy website, "scientific data", and testimonials I could sell the contents of my cats' litter box.
  10. Sep 19, 2008 at 5:21 AM
    ANDYTACOMA
    ANDYTACOMA NOMAD
    2006 access cab trd offroad 4x4 black sand pe
    fog light mod /parking light mod /after market stereo /bed lights/yeasu ft8700/uniden bct15
    I can understand where your coming from Especially in this day and age. Although i don't have an intimate knowledge with this specific company/product, I can say with confidence that this idea is not new. Several companies that i consult for have used this concept in there Finn-power,(And other) Turret punch presses, Press brakes,shears and hydro forming presses to reduce friction,down time and increase longevity of the machines mechanical internals; linear drives,Worm gears,Timing gears and many others. I am NOT saying this company or product is the "golden key".It is a very simple concept that anyone who has ever taken a physics class can understand. When you reduce friction you almost always reduce heat and "cool is the rule"
    especially when we are talking about engines,gears etc.
    other interesting reads on the idea
    1. "http://thefutureofthings.com/news/40/nano-lubricant-to-reduce-fuel-consumption.html"
    2. "http://www.plantservices.com/articles/2003/32.html"
    3. "http://www.nanowerk.com/spotlight/spotid=1174.php" <<< the best ;)
    and now its WIKI time! :D
    Friction is the force resisting the relative motion of two surfaces in contact or a surface in contact with a fluid (e.g. air on an aircraft or water in a pipe). It is not a fundamental force, as it is derived from electromagnetic forces between atoms and electrons, and so cannot be calculated from first principles, but instead must be found empirically. When contacting surfaces move relative to each other, the friction between the two objects converts kinetic energy into thermal energy, or heat. Friction between solid objects is often referred to as dry friction or sliding friction and between a solid and a gas or liquid as fluid friction. Both of these types of friction are called kinetic friction. Contrary to many popular explanations, sliding friction is caused not by surface roughness but by chemical bonding between the surfaces.[1] Surface roughness and contact area, however, do affect sliding friction for micro- and nano-scale objects where surface area forces dominate inertial forces.[2] Internal friction is the motion-resisting force between the surfaces of the particles making up the substance. Friction should not be confused with traction. Surface area does not affect friction significantly because as contact area increases, force per unit area decreases. However, in traction surface area is essential.
  11. Sep 19, 2008 at 5:45 AM
    ANDYTACOMA
    ANDYTACOMA NOMAD
    :confused::confused::confused:
  12. Sep 19, 2008 at 6:09 AM
    Imrubicon
    Imrubicon Wife thinks I am done Modding truck
    Texas
    08 Access 4X4 SR5
    Shhh! the wife thinks I dont do mods on trucks anymore
    I agree with almost all the thing said you said but remember if it was this cheap to improve it they would come from the dealer with it as it would be a high selling point and the STealers would make more money
  13. Sep 19, 2008 at 6:16 AM
    jasonh
    jasonh tossed salad anyone?
    Dallas, TX.
    2007 Pre Runner SR5
    Billy 5100's
    i'd like to see what popular mechanics says about this stuff
  14. Sep 19, 2008 at 6:59 AM
    ANDYTACOMA
    ANDYTACOMA NOMAD
  15. Sep 19, 2008 at 7:24 AM
    neontrail
    Idaho
    What makes XADO different?
    “Snake oil” has become a general term for additives. XADO is not an oil additive. XADO works on metal, not on oil. As the cermet layer forms, the fit and finish of parts is improved, thus placing less demand on whatever lubricant is present in the system.
  16. Sep 20, 2008 at 9:38 AM
    neontrail
    Idaho
    Yes, me too!
  17. Sep 20, 2008 at 8:32 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    So where can you actually buy it? I clicked the buy link, but seems like it's only the one main dealer except for 1 other place in a few states. If it's cheap, I wouldn't mind buying some to see if it helps my car. If it doesn't work, fine. If it does, maybe I can keep the car for a few more years until I have to get rid of it. Since at this point my options are trade it for a new car, or pay $2000 or so to have the engine rebuilt/swapped to keep it from burning so much oil.
  18. Sep 21, 2008 at 7:34 AM
    neontrail
    Idaho
    Try to contact this guy 2 order some. We'll try this route 1st. If you cant buy it thru him.. Let me know. You can also ask him all the questions that you may have. :D
    JNB Rough Enterprises
    114 Rainbow Drive #1473
    Livingston, Texas 77399-1014
    Contact: Jim Roughton
    RV / Trailer Specialist
    214-288-1645
    Or you can go str8 to the top corp office. Tell Daniel that you spoke with Geoff in Texas (Adin's friend) about wanting to order this product.
    Daniel Sanchez
    direct: 505-453-4933
    email:
    daniel@xadousa.com
  19. Sep 27, 2012 at 7:22 PM
    jarpil
    jarpil Well-Known Member
    Kalaheo, HI
    2017 Tacoma TRD OR DCSB, black
    I got it from Amazon. Followed the instructions. I don't notice any changes. Not sure if i should notice anything though.
  20. Sep 27, 2012 at 7:27 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    It has pictures of an engine, a happy family and other motor vehicle stuff...it must work.
