XD CRANK 17 x 9 ...How far will these stick out?
Discussion in 'Wheels & Tires' started by blktaco58, Feb 29, 2012.
  1. Feb 29, 2012 at 5:54 PM
    blktaco58
    blktaco58 [OP] Well-Known Member
    Hawaii
    2012 Tacoma 4wd V6 AC
    884X springs, 1.5" AAL, 16 x 8 MT Sidebitters, 265/75/16 Duratracs, BHLM, Painted Front Valence, Wet Okoles, USA SPEC ipod,
    Im looking into getting some 17 x 9 XD Cranks, below is the specs....
    Size - 17" x 9"
    Bolt Pattern - 6X5.5
    Offset in mm - 0
    Backspacing in inches - 5.00
    Centerbore in mm - 106.25
    I wanted to run some 245/75/17s on them....
    Im not good with the whole Backspacing and measurements, but from these numbers does it look like this combo would work with no rubbing or UCA issues on a stock setup. Also I don't want my rims out past the fender- we have strict laws in Hawaii about this...Anyone with a rim/tire about the same size and backspacing if you could chime in and post if your tires stick out past the flare...
    I know the stock sport rim is 17 x 7.5 and bs of 5.5. So this rim comes out approx 1.25 in more than that stock rim? does that sound right?
  2. Mar 4, 2012 at 11:52 AM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    it would stick out 2" more than stock. .5" from the BS and 1.5" more from the width of the wheel. normally, a 9" wheel with 0 offset is right on the edge of the fenders.
  3. Mar 4, 2012 at 1:40 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    I'm not sure if a 245 section tire is the way to go on a 9" wide rim. Most 265's aren't even spec'd for a 9" wide. Maybe a 8" wide would be a better idea?!
  4. Mar 4, 2012 at 5:36 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yeah there's no way you should be running a 245 on a 9" wide wheel
  5. May 15, 2015 at 5:20 PM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    im not sure if i should post here in this forum.. just that i am looking at the same wheels for my 2005 sr5 4cyl 4x4 5spd base all stock =(other than new frame, extra leaf spring=) i want general grabber at2 tires but want to know what my tire size should be..id like tires to meet edge of fender or just past.. maine also has strict laws.. thanks
