XD HOSS 16" w/ BFG AT ko 285/75
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MMMPinkTACOs, Sep 7, 2011.
  1. Sep 7, 2011 at 6:18 PM
    MMMPinkTACOs
    MMMPinkTACOs [OP] Member
    California
    Bone stock.. for now!
    can anybody help? i just leveled my 09 tacoma and was interested in the XD Hoss 16" but the tire guy says that the 0 offset wont work. i'm going with BFG AT ko in a 285/75 r16. would spacers help with the clearance if so what kind and how big of a spacer should i go?
  2. Sep 7, 2011 at 6:27 PM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    According to 4-wheel parts, the XD Hoss in a 16x8 rim with 0 offset has 4.5" of backspacing, which is recommended by most people on this site. I don't know if this is one of the wheels that will not fit on the 2nd gens due to brake calipers. KPT will probably chime in here pretty soon.
  3. Sep 7, 2011 at 6:31 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Eibachs w/ 5100's set at 0, Rear TSB, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, 265/75/16 Hankook Dynapro ATM Tires, Elusive Elements Mesh Grill
  4. Sep 7, 2011 at 6:35 PM
    MMMPinkTACOs
    California
    i have an 09 TRD off road tacoma crew cab with the short bed. stock rims with 265/70 BFG AT ko. just installed the fabtech level kit today. these tires are just loaners until i find the rims that will fit the 285/75s..
  5. Sep 7, 2011 at 6:36 PM
    MMMPinkTACOs
    California
    the guy that installed my level kit did mention shaving of the calipers for all aftermarket rims.. he also recommended that i look for at least a -12 offset. ive found this offset pretty limited with 16"
  6. Sep 7, 2011 at 6:38 PM
    dpak
    Richmond, VA
    Now that we know you have a 6 lug tacoma, then the link I provided should answer your question. The wheels will fit.
  7. Sep 7, 2011 at 6:39 PM
    MMMPinkTACOs
    California
    do you think he's recommending a negative offset to clear the TIRES?
  8. Sep 7, 2011 at 6:41 PM
    Sport11
    Kingsport, TN
    Dodge Ram 1500
    The 17x9 you would want a -12 offset. The appropriate backspacing and offset changes with the width of the wheel. 4.5" seems to be the concensus for our vehicles, especially with 285 tires.
  9. Sep 7, 2011 at 6:49 PM
    MMMPinkTACOs
    California
    so would i have any problems as far as rubbing running the 16x8 0 offset with the 285/75 BFG? sorry if i'm going in circles with this but i really don't know too much when it comes to the technical numbers.. all i know is i like these rims and i want bigger tires :D
  10. Sep 7, 2011 at 6:58 PM
    dpak
    Richmond, VA
    Yes, you will have rubbing issues with the 285 size tires. There are a plethora of threads about rubbing with 285's and the solution for it. Use the search function to find those threads, it will be good practice.
