XD Series Revolver
Discussion in 'Wheels & Tires' started by clbsprt, Oct 9, 2012.
  1. Oct 9, 2012 at 2:50 PM
    clbsprt
    clbsprt [OP] Member
    cv
    san diego
    2013 PreRunner
    none
    Any information on what the right size tire/wheel package for my new 2013 Tacoma Prerunner with the stock lift would be greatly appreciated. I'm currently thinking 17x9 Revolver wheels with 265/70r/17 BFG rugged terrain or General Grabber tires. :D
  2. Oct 9, 2012 at 2:57 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Those would fit, no problem. XD's are made with a negative offset and will stick out a little bit out of the fender well. I believe you can go 265/75/17 as well without a lift.
  3. Oct 9, 2012 at 3:32 PM
    clbsprt
    clbsprt [OP] Member
    cv
    san diego
    2013 PreRunner
    none
    thank you for the info!
  4. Oct 9, 2012 at 5:15 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    No such thing as a 265/75/17. And OP I'd check to see if those rugged terrains or grabbers are approved for 9 wide wheels. Many 265s are not.
    And what is the backspacing of the wheels you are looking at? Some of the xds do not fit due to too high of backspace.
  5. Oct 10, 2012 at 8:38 AM
    clbsprt
    clbsprt [OP] Member
    cv
    san diego
    2013 PreRunner
    none
    this is what i get from KMC manufacturer: XD801 17x9, 6x5.5 OS: 0mm BS: 5.00
  6. Oct 10, 2012 at 8:47 AM
    TexasTacoma37
    okay, those should be fine as long as the tires are approved for 9" wide wheels.
  7. Oct 10, 2012 at 8:49 AM
    clbsprt
    clbsprt [OP] Member
    cv
    san diego
    2013 PreRunner
    none
    should i go with a wider tire? the tires i've selected are BF Goodrich Rugged Trail - P265/65R17
  8. Oct 10, 2012 at 9:00 AM
    TexasTacoma37
    Those are only approved for 7-8.5" wide wheels, as per the BFG website.
    Can I ask why you want to use that size? (you can fit 265/70/17 with no issues on stock suspension) and that tire? (among the worst tires you can buy)
  9. Oct 10, 2012 at 9:07 AM
    TexasTacoma37
    the General Grabber AT-2's, in 265/70/17, are a much higher quality tire, and approved for 9" wide wheels.
  10. Oct 10, 2012 at 9:10 AM
    clbsprt
    clbsprt [OP] Member
    cv
    san diego
    2013 PreRunner
    none
    thanks for the info, they have now moved to the top of my list!
