XD798 Addict Series
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06tacodude, Mar 2, 2012.
  1. Mar 2, 2012 at 12:33 AM
    06tacodude
    06tacodude [OP] Well-Known Member
    Santa Clara, CA
    06 TRD Sport 4x4
    5100 + 885 + TC-UCA + 1" rear block K&N Drop-in, SG-II, WeatherTechLiners, WestinSideSteps, Hoodstruts, AvicD3, TS-C720PRS, JL10W3V3, ARE LoPro, GrillcraftGrill, Fire&IceLED, HellaBlackMagic, OEM DTRL, RemoteStart, URDMAF, MuthMirrors, Heated Seats
    First off, I'm shopping around for the 17" XD798 Addict Series, there are two versions, but I believe the below is the correct backspacing and offset.
    Part Number: W/PXD79879068712N
    • 17x9 wheel size
    • 6 on 5.5 bolt pattern
    • Backspace 4.5 in.
    • Max Load = 2200lbs
    • Finish = Matte Black
    • Hubcentric = No
    • Offset = -12 mm
    Anyone have pics of the XD798 Addict Series on their truck without the hub caps?
    I'm currently using the stock 17" wheels without a hubcap wrapped with 270/70 Firestone A/T Destination. I like the look with no cap.
  2. Mar 6, 2012 at 9:19 PM
    06tacodude
    Santa Clara, CA
    06 TRD Sport 4x4
    I just had these installed with 270/70/17 AT Destinations. I do have a 2.5" lift in front.
    The problem is that my front tires rub the frame on full turn. Is this an alignment issue?
  3. Mar 7, 2012 at 12:08 AM
    leveltwo
    leveltwo Well-Known Member
