XenonDepot Fall 2018 | What's New + Promos
Discussion in 'XenonDepot' started by XenonDepot, Sep 21, 2018.
  1. Sep 21, 2018 at 8:09 AM
    XenonDepot
    XenonDepot [OP] Well-Known Member Vendor
    Check out XenonDepot.com for great deals on all your Tacoma lighting needs!
  2. Sep 25, 2018 at 12:30 PM
    XenonDepot
    Take a look at new Xtreme LED 921 Bulbs in action which was tested in a Toyota 4runner and compared to a traditional style ''Tower" style LED bulb.
    Danny
  3. Oct 4, 2018 at 1:57 PM
    XenonDepot
    It's been a busy week here at XenonDepot.com and we've just had some fantastic new lighting options arrive:
    The Xtreme PRO DRL LED Driver - this replaces the regular LED Driver found in our Xtreme Pro 9005 LED Kit, and will allow the LED bulbs to dim down in Daytime Running Light (DRL) mode, while still getting full power as a High Beam. Finally the wait is over! You CAN have a 'True' High Beam/DRL option with an LED Kit - no more flickering or DRLs that are just like running your High Beams during daylight hours.
    Already have one of our 9005 LED Kits with the PWM Module option installed and want to upgrade? All you need to do is remove the existing LED Driver and PWM Module, then attach the new DRL Driver to the bulb instead. It's that simple!
    The DRL Drivers were designed and tested based on a 5th Generation Toyota 4Runner, but many other vehicles use a similar PWM power signature with the High Beams and DRLs sharing the same bulb. We are working to compile a list of compatible vehicles, and would appreciate any and all feedback you can provide.
    Want a bright yellow LED solution for your dim Fog Lights? Look no further - we have developed a version of our Xtreme PRO H11 LED Kit with a bright Yellow/Amber colour (2700K) that you can use! Rated at ~1150 stable lumens (after running for about an hour), these make a great upgrade for H8, H11, and H16 Fog Light applications.
    Using the same great design as our Xtreme PRO H11 LED Kits in White (5500K), the Xtreme PRO Yellow H11 LED Kit has its emitters positioned to match the filament from the OEM halogen bulbs, and is also using the upgraded solid heat sink fins found on our regular H11 LED bulbs - now with better heat dissipation.
    ~Robert
    Robb_D likes this.
  4. Oct 11, 2018 at 8:26 AM
    Venti
    Venti Member
    I'm thinking of getting the H11 Kit for my 2018 Tacoma, but need to know what this optional item is please.
    Vehicle Options:With PWM Module
  5. Oct 11, 2018 at 8:29 AM
    XenonDepot
    The optional item is the PWM anti-flicker module which prevents flickering and error codes. This is not needed for the Tacoma.
    Danny
  6. Oct 19, 2018 at 1:56 PM
    new2tt2018
    new2tt2018 Active Member
    Brandon
    2018 Tacoma SR5 DD V6
    Sorry for the dumb question here. I just picked up a 2018 SR5 last week, and I want to upgrade the lights. I'm not "mechanically inclined", so Im looking for just a plug n play set. Are the bulbs H11 and can I just get some extreme pros and pop them in and be on my way?
  7. Oct 19, 2018 at 2:06 PM
    XenonDepot
    The H11 Xtreme LED Pro kit is designed to be plug n play for the 3rd gen Tacoma and it's really not difficult to get to the bulbs. Here's a great installation guide that @RobP62 put together for the low beams and highs:
    2017 Toyota Tacoma - H11 and H8 LED Headlight Review
    Hope that helps,
    Danny
  8. Oct 22, 2018 at 12:29 PM
    dentedporsche
    dentedporsche Well-Known Member
    Ron
    Have you thought about packaging the HID kit with the yellow LED for fogs? Basically, replacing the Baja's
    XenonDepot[OP] likes this.
  9. Oct 22, 2018 at 2:00 PM
    XenonDepot
    Thanks for the suggestion! You can purchase the HID Kits and LED Kits separately and apply any discounts available to them which would make it the same thing.
    Danny
  10. Oct 22, 2018 at 2:07 PM
    Sn4rlax
    Sn4rlax Well-Known Member
    2016 Red Taco 4x4 V6
    https://www.xenondepot.com/H11-HID-Kit-Xtreme-HID-p/xt-h11.htm
    What is the main different between the regular 4300k and the Phillips Bulb 4300k, especially for $45 difference. Looking to pick up the HID set today using that 10% off promo you got running, but don't understand the different between those bulbs.
  11. Oct 22, 2018 at 2:16 PM
    XenonDepot
    The main differences would be the brightness with the Philips being 100-200 lumens brighter and they also color shift to 4700K after about 100 hours of usage.
    Danny
  12. Nov 1, 2018 at 10:29 AM
    XenonDepot
    We're here to help you get ready for winter! With longer nights, your Tacoma or any vehicle for that matter may be due for a lighting upgrade.
    Whether you're looking for a simple halogen replacement or wanting to go with an HID Kit or LED upgrade for your exterior and interior then we can help.
    Send us a PM or reply to this thread with any questions you may have!
    Danny
  13. Nov 9, 2018 at 12:48 PM
    XenonDepot
    Happy Friday everybody!
    Check out this great video showing off our H11 HID Kit, as well as the Xtreme PRO 9005 LED Kit with the Xtreme PRO DRL LED Drivers, all in a newer 4Runner.
    You can really see the difference with the DRL Drivers installed - you get to keep your stock functionality, with DRLs that dim down to a more appropriate level of brightness, while still getting a nice boost in output when they get that full power signal in High Beam Mode.
  14. Nov 15, 2018 at 2:15 PM
    XenonDepot
    Time for another #throwbackthursday!
    This Acura RSX is showing off our Xtreme H1 HID Kit in its Low Beams for a substantial boost in light output.
    Think your Tacoma could use an HID Kit or an LED Kit upgrade? How about some brighter, whiter Interior LED Bulbs? Check out our Vehicle Lighting Guide for options for almost all Years, Makes, and Models.
