Xj axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by DieselDog409, Feb 13, 2024.
  1. Feb 15, 2024 at 3:30 PM
    #61
    Kwikvette
    Fresno County
    4 run, 2 don't
    My solid axle was a champ on snow and mud :crapstorm:
    Nano909 likes this.
  2. Feb 15, 2024 at 3:32 PM
    #62
    02hilux
    Planet: EARTH
    You're statement, "FYI IFS have more ground clearance than a straight axle"
    Very general and vague
    :rofl:
  3. Feb 15, 2024 at 3:33 PM
    #63
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    I'll give you that one. Lol
  4. Feb 15, 2024 at 3:46 PM
    #64
    02hilux
    Planet: EARTH
    I'm mall rated. Posing in the parking lot for the next curb and speed bump victim
  5. Feb 16, 2024 at 5:49 AM
    #65
    DieselDog409
    DieselDog409 [OP] Well-Known Member
    Paul
    Frameless 2000 tacoma V6 5spd e locker rotbox.
    Frame delete cylinder 5 delete glasspack
    Okay i'll just keep the ifs then if the pumpkin of a dana 30 is going to bottom out just like my skid plate does now.
  6. Feb 16, 2024 at 6:23 AM
    #66
    v5ensx
    v5ensx CARB legal is not CALI legal
    WTF do you expect with 31" tires? You expect to have 30" of ground clearance with stock tires?
    Wulf likes this.
  7. Feb 16, 2024 at 6:26 AM
    #67
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Portals.
    TACOTU3 likes this.
  8. Feb 16, 2024 at 6:27 AM
    #68
    v5ensx
    Dude said he ain't got no money so portal is definitely out of his budget
  9. Feb 16, 2024 at 6:29 AM
    #69
    theesotericone
    Bishop CA
    Maybe his local junkyard has some Unimog axles laying around for cheap. lol
  10. Feb 16, 2024 at 9:17 AM
    #70
    Nano909
    Xcab 3.4 4wd 5MT
    I figured "bottoming out" was you getting hung in the front. Running 255/85/16 tires will help. They're a skinny 33" tire that isn't too heavy. But ultimately you'll have to pick your lines correctly so you don't bottom out.
    Ozark_RegCab likes this.
  11. Feb 16, 2024 at 9:28 AM
    #71
    Kwikvette
    Fresno County
    4 run, 2 don't
    I mentioned that some pages ago, he said he doesn't want to give up any MPGs :violent:
    Nano909[QUOTED] and BabyBilly like this.
  12. Feb 16, 2024 at 9:38 AM
    #72
    Nano909
    Xcab 3.4 4wd 5MT
    I hope he realized that going straight axle is way more expensive and fuel inefficient than just using 33's lol
    Wulf likes this.
  13. Feb 16, 2024 at 9:45 AM
    #73
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Ultimately, the only way to gain clearance under the axles / skid plates is tires (or portal axles, but that's not a real consideration for you).
    You also need to take some time and better understand the terms you're using. Hitting the skid plate or diff on a rock, or ground, typically is not considered bottoming out. Bottoming out, usually refers to running out of suspension travel- Either compressing or extending the suspension to it's limit- usually compression. And usually only happens for a brief moment.
    Hitting the diff or skid plate on the ground would be running out of ground clearance. High centering would be the term if you parked your diff on a rock that you couldn't get off of.
    These trucks are extremely capable in their stock form. Learning how to drive around terrain features takes time.
    Strictlytoyz and Wulf like this.
  14. Feb 16, 2024 at 9:50 AM
    #74
    Kwikvette
    Fresno County
    4 run, 2 don't
    I did mention that as well and well, you can see his responses...
  15. Feb 16, 2024 at 10:16 AM
    #75
    TACOTU3
    TACOTU3 Well-Known Member
    2000 Xtracab V6 4x4 TRD
    What is happening here?? I thought SAS was the answer to all problems, suspension or otherwise! We should be trying to talk him up to 40s n tons, not out of it all together… Thought that was in the community guidelines?
  16. Feb 16, 2024 at 10:28 AM
    #76
    Wulf
    rock raisin
    I mean, that kind of talk might have been in the cards if OP had the budget/want to actually invest in the truck and do a proper SAS and not just hack it together with junk for a few hundred to make the truck even worse :laughing:
  17. Feb 16, 2024 at 10:37 AM
    #77
    TACOTU3
    It’s officially Friday so I reject that logic! I dropped a wrench on my toe this morning and am going to treat it with 40s n tons!
  18. Feb 16, 2024 at 1:36 PM
    #78
    v5ensx
    That will be AWESOME with 31s
  19. Feb 16, 2024 at 1:37 PM
    #79
    Kwikvette
    Fresno County
    4 run, 2 don't
    What are you talking about, everyday is Friday :luvya:
  20. Feb 16, 2024 at 1:57 PM
    #80
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Seems to be the going trend lmao
