XM Account Info in Non-Volatile RAM?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RZRob, Mar 27, 2011.
  1. Mar 27, 2011 at 4:11 PM
    RZRob
    RZRob [OP] Well-Known Member
    Robert
    Anaheim Hills
    Hi folks,
    When I bought my used '06 Tacoma it had XM radio. I've had the truck for over a year and the XM hasn't quit. I'm curious though. If I disconnect the battery and reconnect will I need account info to reactivate it? What if I change the Tacoma radio? Can I switch XM receivers or is that going too far and I'll need some special account info? Anyone know the ins & outs of these things?
    RZ Rob
  2. Mar 27, 2011 at 4:15 PM
    Brandon###
    Brandon### Well-Known Member
    There's only one way to find out. Let us know if it stops once you disconnect the battery cables, so I know not to do it.
  3. Mar 27, 2011 at 4:22 PM
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    08 Tacoma Black,Sport package,
    Sport pedals, Extang full-tilt cover, Magnaflow exhaust system, XPEL invisible paint protection, TRD short Shifter, Hood struts, Homelink mirror, Dbl power outlets,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Muth heated signal mirrors TSB. Lo-Tek Pilllar pod with Glow-Shift gauges, 4x4 illuminated switch, Pioneer Z110BT (upgraded to Z130BT) w/2011 toyota tailgate backup camera,traffic tuner, parking brake bypass. Leather interior w/heated seats. LED's installed in glove box, center console, front and rear cupholders, rear console vent, AFE CAI, LED taillights, under hood lights, LED bed lights, oil catch can, extra D-rings installed in bed, frame replaced, Bilstein 5100, fronts set at.85, FOCAL Auditor 6.5" componet speakers. Replaced lower center dash panel with 2011 dash panel, installed USB charger and relocated seat heater switches to lower panel, FLYZEYE lights, APEX stealth LED light bar brackets and Cali Raised LED light bar, Illuminated Ignition Ring,Diff. Breather mod, AC mod.
    I think the XM subscription is based on the radio. I know I had to give them the serial number of the radio when it was activated. I don't think you would have a problem disconnecting the battery, but you might have a problem if you switched radios.
  4. Mar 27, 2011 at 8:58 PM
    enigma429ad
    enigma429ad Well-Known Member
    Olive Branch, MS
    07 PreRunner SR5 DC LB
    I had that XM set up, believe it's a commander. No you won't lose your account if you disconnect. if you switch receivers you'll have to call and tell them to switch serials. the way the commander works though you could switch radios and still plug it into your aftermarket. it has an aux plugin set up or a radio signal you can use.
  5. Mar 27, 2011 at 10:06 PM
    RZRob
    Robert
    Anaheim Hills
    Wow, good information. Thanks folks. I've been nervous about that since day 1. I probably won't switch head units then as I lack any authorization codes etc.
    RZ Rob
  6. Mar 27, 2011 at 10:23 PM
    Stack Knots
    Stack Knots Well-Known Member
    Dan
    Pittsburgh,PA
    2012 Tacoma Off-Road
    Listen to him 100% correct!
  7. Mar 28, 2011 at 5:51 AM
    RZRob
    Robert
    Anaheim Hills
    I sort of knew this, but got my point across - and got the answer I needed. As always, TacomaWorld quenched my thirst for information.
    Thanks,
    RZ Rob
  8. Mar 28, 2011 at 7:15 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    huh?
    Non-volatile memory, nonvolatile memory, NVM or non-volatile storage, in the most basic sense, is computer memory that can retain the stored information even when not powered. Examples of non-volatile memory include read-only memory, flash memory, most types of magnetic computer storage devices (e.g. hard disks, floppy disks, and magnetic tape), optical discs, and early computer storage methods such as paper tape and punched cards.
  9. Mar 28, 2011 at 9:09 AM
    jhodge83
    SC
    but flash memory is also a form of NVRAM as my definition states, so there is such a thing as NVRAM. any RAM that maintains it's data when power is removed is NVRAM.
    Non-volatile random-access memory (NVRAM) is random-access memory that retains its information when power is turned off, which is described technically as being non-volatile.
    NVRAM is a subgroup of the more general class of non-volatile memory types, the difference being that NVRAM devices offer random access, unlike hard disks.
  10. Mar 28, 2011 at 9:34 AM
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    Your codes/serials are on channel 0 w/phone #
  11. Mar 28, 2011 at 12:19 PM
    RZRob
    Robert
    Anaheim Hills
    Wow, I had no idea I'd learn so much today.
    RZ Rob
