XM radio aux input problem
Discussion in 'Audio & Video' started by curley1919, Oct 3, 2009.
  1. Oct 3, 2009 at 10:15 AM
    curley1919
    curley1919 [OP] New Member
    Hopefully someone can help...I'm kind of a knucklehead with these things.
    I have a 2009 Tacoma with an aux input jack and a portable xm radio. All facets of the installation went smooth--antenna on roof, ran the cable thru the weather stripping down thru door jam and under the carpet to the dash. I plug the audio cable from the xm radio cradle into the aux input, turn the car and xm radio on and I get no sound. sound is fine using headset. any ideas?
  2. Oct 3, 2009 at 10:57 AM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I haven't tried it in the Tacoma yet but in my 4Runner you have to turn the volume up pretty darn loud to hear it. Ipod too.
    Don't forget to push aux button on the radio.
  3. Oct 3, 2009 at 12:25 PM
    BPachom
    BPachom Well-Known Member
    Long Island
    09 Tacoma SR5, 4cyl 4X4, Black
    Access roll-up tonneau cover, Factory radio W/Sirius, Tailgate clamp, HID head lights, Stainless nerf bars.
    Some helpful info for both of you, the volume control is adjustable for axillary and satellite inputs, see attached.:cool:
  4. Oct 3, 2009 at 1:00 PM
    warpwr
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    Yeah, I saw that before.
    I haven't tried it yet though.
    Thanks mucho...will try today!
  5. Oct 3, 2009 at 1:07 PM
    Johnny72381
    Johnny72381 Active Member
    Brad
    09 Tacoma pyrite mica
    AMS oil and filter every change, K/N air filter, XM radio, Cb radio, and alot more to come.
    Check and see if your XM reciever has a vehicle mode. If it does go to the vehicle mode and turn the FM modulator OFF. Vehicle mode should be in the menu for your reciever. I hope this works. Im sure it will.
  6. Oct 3, 2009 at 1:15 PM
    BPachom
    Long Island
    Oh, just remembered one other thing..... I have Sirius, my portable tuner has a volume control within the tuner. Do not know if yours does, but you can check it out, if so, turn that up a little.
    Good luck!
  7. Oct 3, 2009 at 1:15 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    That's I'll have to try this out since I can't stand having to have the volume at like 50 for XM just to be able to hear it.
  8. Oct 3, 2009 at 7:18 PM
    BPachom
    Long Island
    Good luck, hope it resolves your issues.:cool:
  9. Oct 3, 2009 at 8:21 PM
    dwzild
    dwzild Well-Known Member
    Metairie, LA
    2010 MGM 4x4 Sport DC LB
    Hoo-rah! Sticker, Front Bed-bolt D-rings, Bed Mat, Weathertech Floor Mats, Sirius, TACOMAWORLD Sticker, Bak-Flip F1
    I have a 2010 and am using the factory antenna, Aux-in and an external Sirius unit with no problems. My aux-in is the same volume as the FM radio/ CD player.
    As posted above, make sure your volume is up on your external unit.
  10. Oct 5, 2009 at 5:21 AM
    curley1919
    Thanks to everyone for replying. Maxing out the volume on the truck radio worked like a charm--I also increased the "Line Out Level" on the XM radio. Even better is that each AM, FM1, FM2 and CD/AUX have their own volume setting, so I don't have to worry about switching from AUX (volume maxed) to FM1 (volume low/middle) and have the radio blaring.
  11. Oct 6, 2009 at 3:51 AM
    BPachom
    Long Island
    Curley,
    Glad that it worked out:thumbsup:
  12. Apr 14, 2010 at 2:23 PM
    GloryGamer24
    GloryGamer24 New Member
    Wyoming
    09 Tacoma SR5
    Hey, I have a 2009 Access Cab Tacoma and when I plug either iPod or Sirius into the aux input sometimes the right speaker doesnt work, and when it does there is no bass. Was wondering if other people were having the same problem and knew what was wrong.
