XM radio problem
Discussion in 'Audio & Video' started by fullback, Nov 17, 2010.
  1. Nov 17, 2010 at 3:04 AM
    fullback
    fullback [OP] Well-Known Member
    NJ
    Double Cab TRD short bed
    My 2009 Taco came with XM antena Built in. when i installed the Navigation Head unit with Audiovox XM tuner (aftermarket) my installer could not use the factory Built in Antena, so he opted for external antena on the dash . I lose signal at lots of locations as i drive , in NJ . My installer also advised me the Toyota Fit Kit does not work with the Audiovox,Tuner Kit either, so i did not bother getting the Kit from the Dealer . Now I am also contemplating changing to Sirius Radio, which i think i have to get a whole new Tuner and internal antena??? Any suggestions. Thanx In advance:confused:
  2. Nov 17, 2010 at 3:09 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Move the antenna to the outside. Problem solved.
    FWIW, on my last vehicle I had aftermarket equipment and had my XM antenna on the dash and it was fine and didn't cut out except for the normal trees or building blocking signal. Didn't work nearly good in the Tacoma when I installed an aftermarket HU a couple weeks ago with the XM Direct kit. I moved it to the front passenger side corner of the roof. Doesn't cut out at all now and I get better reception than I did with the factory Toyota XM crap.
  3. Nov 18, 2010 at 8:14 PM
    fhlashsf
    fhlashsf Well-Known Member
    Curt
    Danville, CA
    '10 Off Road Double Cab 4x4
    Weathertechs, Avid bolt-on sliders and light bar, 17" ATX Thug wheels, BF Goodrich AT 285/70/17 tires, Icom 2820 Dstar radio, OME 3" lift, color matched rear bumper and Grillecraft grille, Wet Okole seat covers, ARM bed extender, black badges, Sockmonkey decals, HID headlight and foglights, TRD cat back exhaust, TRD CAI, URD MAF calibrator, Kenwood 6960 HU, Image Dynamic front and back speakers, ARC Audio Sub in Mr. Marv custom sub box and amp rack, Tuffy security box for bed.
