XM radio volume
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blair1120, Jun 8, 2009.
  1. Jun 8, 2009 at 9:22 AM
    blair1120
    blair1120 [OP] New Member
    delaware
    09 4cyl 5spd 4X2
    Hi- just put in an XM radio and tied into the 2009 Tacoma factory radio via the auxiliary input. Both the volume on the XM radio and the factory installed radio is at maximum yet the sound level is only moderate. Any noisy road surface or the windows open drowns out the radio. Anyone have any fixes?
  2. Jun 8, 2009 at 9:33 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Does it have a seperate amplifier? I remember something about when I installed my setup in my JBL system a little while ago stating that you had to have the volume at midrange before you installed any seperate systems, otherwise the amp would stay at the given volume once installed with a different system. This would make the volume stay low if you left it on low when you pulled it apart.
    Not really sure any better way to explain it, this may not be your scenario though.
  3. Jun 8, 2009 at 10:03 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The input sensitivity of the Toyaota aux input is very low and some devices need a step up amplifier to get a decent volume level. Why don't you use the factory XM input?
  4. Jun 8, 2009 at 10:27 AM
    blair1120
    delaware
    09 4cyl 5spd 4X2
    The XM does not have a separate amplifier- its a base unit. Where is the factory XM input? the only thing I saw was the Aux input. Maybe just didnt look hard enough.
