XM/Sirius Radio Antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CockoMeaty, Jul 22, 2010.
  1. Jul 22, 2010 at 8:28 AM
    CockoMeaty
    CockoMeaty [OP] Member
    Louisville, Kentucky
    10 Pre-Runner
    Does anyone have any information regarding the use of the roof mounted antenna with the OEM SatRadio? I've got a '10 DC (non-JBL)
    I've pulled the install instructions on Sirius and it shows an additional antenna. I've also pulled in the install instructions for XM and it shows an antenna cable. Obviously I would perfer the use of the roof mounted antenna and there is no difference to me on which service I use.
    Thanks in advance for the help.
  2. Jul 22, 2010 at 8:42 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    You can get an antenna adapter at tssradio.com, it plugs in down by the kick panel. You will also need a tuner to use the factory radio, the whole package with antenna tuner is about 150 IIRC. Look in the audio forum there is a sat install thread for an 09 I think, should be the same.
  3. Jul 22, 2010 at 11:18 AM
    CockoMeaty
    10 Pre-Runner
    Sounds like the best way to go!
    Where is the connection made with the SFA12M? Meaning, does the headliner need to come down or does it it plug in around the kickpanel?
  4. Jul 22, 2010 at 11:20 AM
    CockoMeaty
    10 Pre-Runner
    Nevermind I think I answered my own question....kickpanel.
  5. Jul 24, 2010 at 8:24 AM
    CockoMeaty
    10 Pre-Runner
    I am well aware that the Radio is capable and I needed the kit, which I bought from Toyota. The only question I had was regarding the roof mounted antenna.
  6. Jul 24, 2010 at 8:39 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I was in the same boat as you and ended up buying the XM tuner and "fit kit" (wiring) from toyota as well . I installed it in less than a half hour, using the roof mounted antenna. You don't even need to remove the HU. Here is a pdf with the part numbers and install instructions for others who are interested.
  7. Jul 24, 2010 at 9:22 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    what is a good rate to pay XM for service?
