XM with poor reception with Jbl system.Techs please chime in.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fireboss, Sep 16, 2010.
  1. Sep 16, 2010 at 5:10 PM
    Fireboss
    Fireboss [OP] Member
    Washington
    2010 Tacoma D.C. Trd Sport
    Heated Seats, Canopy, Twin Dual Band Radios
    I have a 2010 Tacoma Trd Sport double cab 6sp, it has the factory Jbl sound sytem with built in Xm tuner in the factory radio, the Xm module is not under the rear seat. I have had this back to our dealer many times trying to fix the poor Xm reception, Im a Sirius subscriber in my other truck, it never goes out (of course tunnels,overpasses, forest,etc.) this Xm is out alot of my driving. Our dealer replaced the entire radio module, and the Oem roof top antenna located on the back center of the cab, they have now ordered an entire harness to replace the coax, hoping its a bad/smashed coax. I would like to troubleshoot this myself also, Im qualified with the tools, knowledge, equipment, spare antennas, etc. I have never seen this white coax connector that is in the drivers kick panel, normally Xm/Sirius will use a SMB connector, but not Toyota, I have been to the Tssradio website, but they only offer an adapter to replace the radio, not the antenna, as I would like to test with other antennas, before my dealer rips out my harnesses. What am I missing.? Thanks in advance. And yes of course its white.!!
  2. Sep 16, 2010 at 5:17 PM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    My 2011 Tacoma TRD Off road w/JBL is the same way, even the standard FM does not have good reception. XM goes in/out a lot more frequently than other XM equipped cars.
  3. Sep 16, 2010 at 5:27 PM
    Fireboss
    Washington
    Im going to get to the bottom of this, I just have to figure out how to connect to their unusual coax connector, I have everything else to test with, I cant cut out that connector yet, as they will be replacing the harness next week. When I figure this poor signal problem out, I will post it for everyone else who has this problem.
  4. Sep 16, 2010 at 5:31 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    hondas have the same problem,the XM reception is terrible
  5. Sep 16, 2010 at 5:34 PM
    Firetech
    Firetech Well-Known Member
    Ralph
    Maryland
    2010 SR5 Off Road
    I had to buy a (shark fin adapter cable) to hook up my Sirius radio to the installed antenna. About $70.00. Do a search, there is a good write up with pictures. I get grate reception.
  6. Sep 16, 2010 at 5:42 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea I find the Toyota XM receiver to be kind of garbage. Never had any issues with the OEM and aftermarket units I had in my last vehicle.
  7. Oct 14, 2010 at 4:06 PM
    Fireboss
    Washington
    Firetech, I have not been able to find an adapter that uses the factory antenna, to connect to a stand alone Sirius module, any ideas or where did you find one.??
    The saga goes on, Toyota replaced the entire rear harness in my Tacoma, this includes the coax from the drivers kick panel to the roof top antenna, hoping this will fix the poor reception problems, they also replaced the entire radio head/xm again trying to fix this, I will give them alot of credit, they are sure doing everything they can to fix this. I think Mt Madman is right on the money with the non-standard white plastic coax connectors in the drivers kick panel is their problem, but without adapters, I cant test or prove this. Any one have any ideas on this.??
  8. Oct 15, 2010 at 4:14 AM
    Firetech
    Ralph
    Maryland
    2010 SR5 Off Road
    Do a search on this site for a SFA12M antenna cable. This cable connects from that white connector by the drivers left kick panel to your sirius radio.
  9. Oct 15, 2010 at 4:54 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
  10. Oct 15, 2010 at 9:21 AM
    amati5
    amati5 Well-Known Member
    2010 Prerunner TRD
    I have the exact car, DC TRD with JBL and my Xm radio or FM/AM have never lost reception unless when I am in the indoor parking.
    Here is the question that I never got an answer for: Is Xm radio permanently free with JBL option or only 6 mos/1yr deal and you have to subscribe after?
  11. Oct 15, 2010 at 10:12 AM
    amati5
    2010 Prerunner TRD
    It'll be 1 year in 5 days. Let see if it still works after that.
  12. Oct 15, 2010 at 10:49 AM
    Firetech
    Ralph
    Maryland
    2010 SR5 Off Road
    Don't call them until they shut it off!!
  13. Oct 15, 2010 at 1:22 PM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    I've got a 2010 DC prerunner with the same radio package and the XM reception is a bunch of crap. I'm just going to let the free trial period run out and then forget about satellite radio.
  14. Nov 11, 2010 at 9:17 AM
    ssiboogie
    ssiboogie New Member
    Dave
    Georgia
    11 4x4 SR5 Double Cab
    Seats Front Leather Camo Rear, ARE Tonneau Cap
    I have a 2011 and the XM reception is the worst I've ever experienced. I have two other vehicle installed systems which work very well; One of the original Pioneers using the ancient twin lead antenna cable, and the other an original Delphi. In my neighborhood there is a single location where signal drops out if waiting at a particular spot at the lights. The JBL built in system however provides dropouts almost anywhere I'm driving, sometimes for long periods. This appears to be an engineering design problem. I think two contributors solved their problem by adapting the stock antenna to an after market receiver which strongly points to the JBL receiver being the problem. It appears that no matter what is replaced nothing changes unless the radio is replaced with an alternative after market unit. It is a little surprising Toyota and particularly XM have allowed this problem continue. I bet here are thousands of people out there by now who wouldn't touch either JBL equipment or XM radio based upon their experience with this particular implementation.
  15. Nov 11, 2010 at 11:23 AM
    teej
    teej Active Member
    NH
    '10 TRD Sport Dbl Cab
    OEM bed mat, Extang Trifecta tonneau, XM satellite radio, remote start, bull bar, hella 500s
    i've had both services XM and Sirius and i think i always had better signal reception with Sirius. I recently bought my tacoma and had XM installed since its already setup for it and i don't seem to have any worse reception than the Sirius.
    it could be the antenna wire. i had one that was cracked one time and replaced it and it made a big difference
  16. Nov 11, 2010 at 11:27 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Reading > Firetech
  17. Jan 15, 2011 at 7:23 PM
    chillman1971
    chillman1971 Member
    Ray
    Lacey, Wa
    2010 DC Off-Road 4x4
    TSB-Leaf springs
    I have an 2010 DC Tacoma Off-Road with the JBL stereo and it has very poor XM reception. I drive down I-5 and lose signal. I haven't addressed it with the dealer yet. Has anyone had any success with increasing the reception? If so, how.
  18. Jan 16, 2011 at 5:11 AM
    Steig
    Tacoma TRD off road
    Same issue here, 2011 Tacoma DC off/road w/JBL. Radio reception is not the best with XM or FM.
  19. Jan 16, 2011 at 5:29 AM
    rm2092
    rm2092 Well-Known Member
    I just bought a 2011 TSS Prerunner that had no XM and and a non JBL Radio so the dealer installed aftermarket XM and the intenna was mounted in the front of the cab and I must say the reception is better then any other I had installed from the factory.
  20. Jan 17, 2011 at 2:07 PM
    Frogdaddy
    Frogdaddy Well-Known Member
    Ga.
    2010 PreRunner SR5 DC
    Pioneer MVH-p8200 hu with XM receiver using TSS supplied shark fin cable, Mud Flap cut mod.
    I've installed a pioneer hu with pioneer xm receiver. Ordered the SFA12M to utilize stock shark fin. Reception on it is great with exception of going under a bridge in or a garage as expected. So, perhaps you have a bad cable? It's pretty thin cable. Almost a 40lb test kind of thin.
