xmas tree sap laughs at goo gone
Discussion in 'Detailing' started by jmast, Dec 16, 2012.
  1. Dec 20, 2012 at 7:14 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Butter works better
  2. Dec 20, 2012 at 7:15 AM
    OZ-T
    Peter North
    British Columbia
    Ya Ben
    Like duh
  3. Dec 20, 2012 at 7:22 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Dec 20, 2012 at 7:25 AM
    OZ-T
    Peter North
    British Columbia
  5. Dec 20, 2012 at 7:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's not butter...even says so. FAIL
  6. Dec 20, 2012 at 12:45 PM
    OZ-T
    Peter North
    British Columbia
    I can't believe it
  7. Dec 20, 2012 at 12:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    Mind blown...
  8. Dec 20, 2012 at 12:52 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    hand sanitizer works great
    just wash it off when your done
  9. Dec 20, 2012 at 12:58 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  10. Dec 20, 2012 at 1:04 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    :rofl:
  11. Dec 20, 2012 at 1:38 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    :facepalm:
  12. Feb 14, 2013 at 12:54 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    did the butter work?
  13. Mar 4, 2013 at 10:06 AM
    allthom
    allthom Member
    Grab a bottle of methyl hydrate and apply some to a cloth and rub it over the sap, apply light pressure and keep rubbing back and forth. If your truck is a dark color you will need to polish the area afterwords if you apply too much pressure while using the methyl hydrate it will scratch the clearcoat but it will take the sap off completely. Been using this to remove tree sap in a detailing shop and it works wonders, nothing else will remove it. Make sure to apply some sort of wax afterwords to protect the paint!
  14. Mar 4, 2013 at 10:12 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    similar to remvoing emblems, try using a blow dryer/heat gun to slowly heat up the sap.
  15. Mar 8, 2013 at 10:28 AM
    #35
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    I'll second the above poster....use a hair dryer to heat it up. Will work like magic
  16. Mar 11, 2013 at 11:52 AM
    #36
    sde780
    sde780 Well-Known Member
    Rubbing alcohol/Meguiar's ultimate compound has always worked for me.
  17. Jun 4, 2013 at 1:32 PM
    #37
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Old #7
    apply, let sit, apply, wipe.
    Repeat as necessary.
  18. Jun 4, 2013 at 1:43 PM
    #38
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Fuck it.
    Take a grinder and cut out the sheet metal around the sap.
    Clearly the only way to remove the sap.
  19. Jun 4, 2013 at 1:53 PM
    #39
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    :laugh: +1 for you sir
  20. Jun 4, 2013 at 1:58 PM
    #40
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    armor-all cleaning wipes work too, takes a bit of elbow grease but sap-b-gon
