XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Mar 15, 2012 at 9:00 PM
    #181
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    He text me some yesterday :thumbsup:
  2. Mar 15, 2012 at 9:11 PM
    #182
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
  3. Mar 16, 2012 at 1:02 AM
    #183
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    How is this a great build??
  4. Mar 16, 2012 at 7:10 AM
    #184
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man. Was thinking about that, but i think it would be too much white. It would look like an FJ. Lol. I'm still trying to figure out the color theme and pattern for that center strip down to the center console
    I hate you... We are no longer friends. :D
  5. Mar 23, 2012 at 8:41 AM
    #185
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Just ordered the last of my lighting from TRS. Love those guys. knowledgeable, great customer service, and great prices. Can't wait to be done with my lighting.
  6. Mar 23, 2012 at 8:44 AM
    #186
    PLC721
    Patrick
    Chandler, Az
    Is it possible to put your eBay bowl/bezel etc in a factory housing?
  7. Mar 23, 2012 at 8:50 AM
    #187
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hmmmm, probably. Would be just like doing a retro. Don't have a shroud tho. Wanna do our led's when I do my lights next week?
  8. Mar 23, 2012 at 8:54 AM
    #188
    PLC721
    Patrick
    Chandler, Az
    Yeah probably, if you can do it swap in a factory housing!
  9. Mar 23, 2012 at 8:56 AM
    #189
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    You want me to swap the ebay projectors into a reflector housing? They wont be that good tho. Hence why I swapped mine.
  10. Mar 23, 2012 at 9:02 AM
    #190
    PLC721
    Patrick
    Chandler, Az
    No put all of the eBay stuff, into a stock housing. Just the housing switched
  11. Mar 23, 2012 at 9:07 AM
    #191
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thats what I just said. Lol like a retro... Right?
  12. Apr 11, 2012 at 8:12 AM
    #192
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Just updated my list in the OP.. had to change some stuff around. Think I finally have it figured out tho.
    Also, finished my headlights... FOR GOOD! Finally have them how I want them. Color, cutoff, etc. Installed my LED'S in the map, dome, and license plate as well.
    Need to wash the truck and get some updated pics.
  13. Apr 11, 2012 at 8:32 AM
    #193
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    Try the Alpine Type R shallow or RF P3 shallow. I have the P3 and it hits really hard, even though it is underpowered.
    And try this site for a box. Most of them are made from MDF http://www.hifisoundconnection.com/Shop/Control/fp/tcat/27986/SFV/30046
  14. Apr 11, 2012 at 8:36 AM
    #194
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    have you installed the switches that you bought at Sierra expeditions? i bought two that i need to switch out. I need to get new Build pics too
  15. Apr 11, 2012 at 8:58 AM
    #195
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah I did. I popped out the the vsc and trac switches since Ive hated them from day one, and have the ABS killswitch.. and put the new switches in their spots. :)
  16. Apr 11, 2012 at 10:18 AM
    #196
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    so do they fit without modification. Will said i may have to dremel it a bit to fit
  17. Apr 11, 2012 at 10:22 AM
    #197
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah, the holes need to be trimmed a bit. I just used my knife and cut away the plastic tabs that hold In the stock switches. Basically making it a larger opening.
  18. Apr 11, 2012 at 2:10 PM
    #198
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I hate your work schedule too. Lol. It's been too long man. We havent gone wheelin or anything in months! no bueno.. :(
  19. Apr 24, 2012 at 5:16 PM
    #199
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    well... so much for trying to stick to my "plan" shit keeps coming up, or i find something else to blow money on.. I think im better off just goin with the flow.. as much as i hate not sticking to a plan or being organized.. its less stressful to just forget about it and go witht the flow and get stuff done when i can.
    Also, I DO have to take the headlights apart... AGAIN. the plastic nut for the adjuster screw on the inside of the housing is stripped im guessing, because when i hit a big enough bump, my headlight aiming goes completely out of whack.. SO.. ill have to bake them again and fix that.. while im in there ill probably make some small adjustments to the rotation to get the DEAD ON, along with messing with the cutoff to get a little less blue. just means more trial and error.
    one more thing.. the dreaded thought of LT is still floating around in my head.. S/C'd, 4x4, LT = BADASS. lol
    BUT.. that means bye bye clean, silent, sleeper truck.. hello loud, modded, beast.
    idk.. thats way down the line.. still have to finish this so called "plan" lol
    /Rant
  20. Apr 29, 2012 at 3:30 PM
    #200
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Few pics from this weekend..
