XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Mar 24, 2014 at 11:08 AM
    #2661
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :pout:
    IM SORRY!! lol
    dont leave me Adam! atleast i remembered.. and how is not the proper reply?
    "no, do you?" isnt that it??? lol
    then the girl (Vasqez right) and the other heavy weapons guy do their little handshake
  2. Mar 24, 2014 at 11:14 AM
    #2662
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    It's "No. Have you?"
    And it's Vasquez/Drake, the two smartgun carriers
  3. Mar 24, 2014 at 11:15 AM
    #2663
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    damn you and your proper english. lol
    fine.. fine.. you win. :p
    my favorite line that she says in that entire movie.. is right before her death.. "You always were an asshole Gorman" and then Boom.. lol badass till the last second of her life. lol
  4. Mar 24, 2014 at 11:15 AM
    #2664
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yup im on the reflash
  5. Mar 24, 2014 at 11:17 AM
    #2665
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    what about having Toyota do another flash?
  6. Mar 24, 2014 at 11:22 AM
    #2666
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Yeah that was a good part. The only time Gorman had any balls.
  7. Mar 24, 2014 at 11:24 AM
    #2667
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    true that. he somewhat redeemed himself when he couldnt make the right calls and got squad members killed. lol
  8. Mar 24, 2014 at 12:08 PM
    #2668
    memario1214
    Colton
    Missoula, MT
    They can suck my balls. I really dont think its that. I did have a bad battery... so anything is possible.
  9. Mar 24, 2014 at 12:24 PM
    #2669
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just thinking maybe a fresh flash would get some possible bugs out or somethin.
  10. Mar 24, 2014 at 1:32 PM
    #2670
    memario1214
    Colton
    Missoula, MT
    Hopefully a tranny check can iron SOMETHING out anyway
  11. Mar 24, 2014 at 1:39 PM
    #2671
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    that would be a good start thats for sure. i sure hope you dont need a new tranny :(
  12. Mar 24, 2014 at 3:17 PM
    #2672
    memario1214
    Colton
    Missoula, MT
    Fingers crossed here's to hoping I just need new fluid
  13. Mar 24, 2014 at 3:22 PM
    #2673
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    *fingers crossed*
    speaking of fluid.. what do you recommend for coolant? Toyota? noticed mine was on the low line yesterday. didnt check it prior to our wheeling trip.. so im not sure what the level was prior or if that had any affect on it.
    Didnt run hot at all, ran great. so not sure why it was so low.
  14. Mar 24, 2014 at 3:49 PM
    #2674
    memario1214
    Colton
    Missoula, MT
    Toyota premixed pink stuff. Only stuff you should run.
  15. Mar 24, 2014 at 4:13 PM
    #2675
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
  16. Mar 24, 2014 at 8:33 PM
    #2676
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I just put Zerex Asian formula in mine. I wouldn't mix with stock coolant but for drain and fill it should be good.
  17. Mar 24, 2014 at 10:24 PM
    #2677
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Chances are it's beem that way since the blower install man. Unless you were checking it. The hoses had to ve replaced and a bit of extra capacity needed for it.
  18. Mar 25, 2014 at 9:49 AM
    #2678
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ok, I figured as much. Ill have to swing by the dealer and pick some up.
    oooooh. lol :thumbsup:
    I honestly cant even remember.. lol
  19. Mar 25, 2014 at 10:30 AM
    #2679
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Don't forget about the Toyota Red coolant. Have to mix it yourself.
  20. Mar 25, 2014 at 10:53 AM
    #2680
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    what do you recommend sir?
