XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Aug 30, 2014 at 2:44 PM
    #3021
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    What the fuck?
  2. Aug 30, 2014 at 5:12 PM
    #3022
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Brap brap haha jk I love you josh :)
  3. Aug 30, 2014 at 5:34 PM
    #3023
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So.....true dual straight pipes?
  4. Aug 30, 2014 at 6:23 PM
    #3024
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Not dual.. so I guess technically not straight pipes huh?
    Its headers->2.25" piping Y pipe->2.25"in/3"out collector->3" piping->muffler
  5. Aug 30, 2014 at 8:18 PM
    #3025
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Would mine count as straight piped then?
  6. Aug 30, 2014 at 11:21 PM
    #3026
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Don't know what you have..
    So.. ill admit.. I'm a complete n00b when it comes to exhaust. Like I've stated before.. performance isn't my strong suit.. lol.
    With that being said.. after some research.. and actually taking the time to learn about the exhaust components (cats vs resonators) etc.. I think I know what needs to be done to my exhaust now.
    I have no cats, this is due to the removal of the factory manifolds that had the cats attached, and were replaced with the URD headers which are considered a long tube, which eliminates the cats, needing the o2 Sims.. this is what can cause rasp and why DTLT get its reputation for rasp.. as well as the URD y-pipe since it doesn't have resonators.
    So.. since I don't have cats, which I'm ok with.. since I have the o2 Sims.. and I don't have resonators.. I'm getting the loud/rasp/drone/buzz..
    Solution.. 1) add one resonator in front of the Aero muffler or 2) add two resonators on the new y-pipe just how the factory y was.
    Am I getting all this close at least? :eek: Lol.
    Now.. which resonator? now many? What length? What size (depending on if i add them to the 2.25" y-pipe or the 3" after the y-pipe) And will this help tone it down.
  7. Aug 30, 2014 at 11:25 PM
    #3027
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    From what I understand, all resonators do is take away rasp and drone. My buddy who's life is performance (fox body mustang). He says they're basically glass packs. So yes. Add a resonator. Lose rasp and drone.
  8. Aug 30, 2014 at 11:48 PM
    #3028
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Isn't there a resonated version of your muffler?
  9. Aug 30, 2014 at 11:57 PM
    #3029
    JerryTaco
    JerryTaco Well-Known Member
    You should talk to Matt (StillWill). He's done his exhaust over a few times and from what I could tell on his YouTube video, it sounds super dialed now. Supercharged like yours bit his crazy exhaust setup makes his truck sound super mean
  10. Aug 31, 2014 at 1:05 AM
    #3030
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    :spy: I'll let you talk your way through this, but you know I hold the answers lol. You're on the right track though
  11. Aug 31, 2014 at 4:54 AM
    #3031
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Cool! Thanks for the heads up man.
    Well that's why I posted.. for you guys to chime in.. so.. chime away. Lol
  12. Aug 31, 2014 at 8:38 AM
    #3032
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    You need to add either a resonator in front of the muffler or 1 on each side of the y pipe. I know the vibrant ones are popular but don't have any first hand experience with them
  13. Sep 1, 2014 at 8:07 AM
    #3033
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Keep in mind though, having no cat's could make you fail emissions inspection. Even though they do the ECU test, they always do a visual check to ensure they're there for my cars too.
  14. Sep 1, 2014 at 8:47 AM
    #3034
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This was my concern as well.. but was banking on them not doing a visual. Or.. registering it up here at my parents..
    Or.. can I still add cats?
  15. Sep 1, 2014 at 8:52 AM
    #3035
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    The "safe" route, pending you keep it registered here of course, is to just do a pair of high-flow cats. Those alone may actually help your resonation a bit too, plus give you a little back-pressure which is also a good thing.
  16. Sep 1, 2014 at 9:09 AM
    #3036
    PLC721
    Patrick
    Chandler, Az
    I just went through emissions and they did no sort of visual check to see if I had cats or not
  17. Sep 1, 2014 at 9:15 AM
    #3037
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Yea it just depends on who you get. Sometimes you get lucky, sometimes you get some old hag that lives to make people's lives a living hell.
    The best was when they tried to do a dyno load test on my TT awd stealth and put the rear tires on the dyno and was about to shift it into gear. They used to lock you in the little box thing when they did the test too, fortunatly between yelling and screaming loud enough I got his attention enough to tell him it was AWD. Dude turned white so fast knowing he almost rear ended the car in front...
  18. Sep 1, 2014 at 9:18 AM
    #3038
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Right.. so the high flow cats would be added into both sides of the y correct? I'm actually wanting to do this as well, I just wasn't sure if I could add cats, to a system that removes them (long tube headers)
    And this.. if just a resonator would help with the drone and loudness, I may just do that.. for simplicity sake.. but.. I would feel better not having anything that could screw me.. plus the cats would help with the rasp/drone.
    Decisions.. decisions..
  19. Sep 2, 2014 at 9:16 AM
    #3039
    Aw9d
    Aw9d That one guy
    Did they keep your cats?
  20. Sep 2, 2014 at 9:31 AM
    #3040
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    idk.. maybe. not too worried about those. just trying to get a resonator in there now. its going to the shop today.
    you see those LED strips i got? ;)
