XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Sep 8, 2014 at 6:04 PM
    #3121
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I can't find it!
  2. Sep 8, 2014 at 6:05 PM
    #3122
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    bastard!! :p oh well. im plannin on crankin em up friday night probably. then off to Firestone Saturday morning
  3. Sep 8, 2014 at 9:28 PM
    #3123
    JerryTaco
    JerryTaco Well-Known Member
    Sounds good to me... I might be thinking about making a switch from my icon set up
  4. Sep 8, 2014 at 9:49 PM
    #3124
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Really? Why so?
  5. Sep 8, 2014 at 9:49 PM
    #3125
    PLC721
    Patrick
    Chandler, Az
    This girl looked mighty fine tonight!
  6. Sep 8, 2014 at 9:52 PM
    #3126
    JerryTaco
    Meh, just so damn stiff for day to day street driving..
  7. Sep 8, 2014 at 10:30 PM
    #3127
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks buddy! It needs a few tweaks still. ;)
    Really?? Intetesting..
    Ill be cranking mine up here in the next couple days so we will see how it rides and sits after.
  8. Sep 8, 2014 at 10:50 PM
    #3128
    JerryTaco
    I am also looking at doing spindles so I can take all the pre load out of my coil overs and then replacing the resi's on the rear shocks with some cdcv resi's. Just trying to get a little more comfortable ride on the road
  9. Sep 10, 2014 at 8:47 AM
    #3129
    Aw9d
    Aw9d That one guy
    Or so you thought.....
  10. Sep 10, 2014 at 8:50 AM
    #3130
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    right?? :/
    about to run to SDHQ and drop it off. thanks again for lettin me borrow Betty White. lol
  11. Sep 10, 2014 at 8:58 AM
    #3131
    Aw9d
    Aw9d That one guy
    No problem. Hope everything works out. Tiff took her F4i to work and she seemed rather excited to ride her motorcycle again. I have her 4 Runner to go dick around with.
  12. Sep 10, 2014 at 12:30 PM
    #3132
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Think I could borrow your sway bar sometime? I want to test something...
  13. Sep 10, 2014 at 12:32 PM
    #3133
    Aw9d
    Aw9d That one guy
  14. Sep 10, 2014 at 12:37 PM
    #3134
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  15. Sep 10, 2014 at 10:58 PM
    #3135
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So coilovers are back on. after a mishap with the collar on the passenger side King... I popped a thread. threw my OME back on and limped it into the garage. took the King to SDH and had them compress the coil and re-seat the collar, plus finish adjusting it for me. through it on tonight. driver side might need to come up just a tad more tomorrow to rid the taco lean. other than that. no issues. getting the alignment friday.
    but.. did notice that my passenger rear tire seems to protrude from the fender more than the driver. not sure if that should be a concern or not. looks like a good inch or at least 3/4".
  16. Sep 11, 2014 at 8:40 AM
    #3136
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Need to recenter the axle, if that is the case.
  17. Sep 11, 2014 at 8:56 AM
    #3137
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    go oooon.. lol
    im wondering if its related to my taco lean. would make sense if the driver side is lower, pulling the rear fender lower on that.. resulting in showing more tire on the opposite (passenger) side.
  18. Sep 11, 2014 at 9:03 AM
    #3138
    PLC721
    Patrick
    Chandler, Az
    Remember you notices by pass rear sticks out a solid 1" more??
  19. Sep 11, 2014 at 9:25 AM
    #3139
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I know ;) so.. what was the outcome of that anyways? wasnt it your bed or bedsides?
  20. Sep 11, 2014 at 9:26 AM
    #3140
    PLC721
    Patrick
    Chandler, Az
    I thought so, but i swear my pass tire sticks out further still, maybe one day ill jack it up and mess around with the leafs and axle
