XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Sep 11, 2014 at 9:57 AM
    #3141
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    hmm. i may have to do the same thing then.. mini mod day soon for it? lol
  2. Sep 11, 2014 at 10:16 AM
    #3142
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    It has to be the bedsides unless you tweaked the frame or the leafs somehow poped out of position on the axle... but that's virutally unpossible.
  3. Sep 11, 2014 at 10:19 AM
    #3143
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Well it was that way with stock bedsides and now glass, thinking it's the sua where we put the new perches may be half inch off
  4. Sep 11, 2014 at 10:21 AM
    #3144
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Oh yea, that whole you welded a new position onto it thing lol. Yea I suppose that's possible :p
  5. Sep 11, 2014 at 10:21 AM
    #3145
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Wonder if mine just got twisted/shifted when installing the leaf packs.
  6. Sep 11, 2014 at 10:25 AM
    #3146
    PLC721
    Patrick
    Chandler, Az
    Well in theory the centering pins would prevent that from happening
  7. Sep 11, 2014 at 10:26 AM
    #3147
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Would be really hard to fuck that up. The leaf have a centering pin and the perches have an alignment hole
  8. Sep 11, 2014 at 10:54 AM
    #3148
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    agreed. and they are definitely seated in there correctly. i made sure when installing. just trying to think of anything that could cause it.
  9. Sep 11, 2014 at 11:04 AM
    #3149
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    OCD ;)
  10. Sep 11, 2014 at 11:25 AM
    #3150
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you tighten all of the leaf hardware while on jack stands, or on the ground, under its own weight?
    I have seen them be off plenty of times, from a new leaf installation. I have also seen my own truck have a wheel stick out to one side, after parking directly after taking a turn. Soft ass three leaf pack......
  11. Sep 11, 2014 at 11:33 AM
    #3151
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    How do you like those urd headers? Did you just have the stockies before?
  12. Sep 11, 2014 at 11:37 AM
    #3152
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    THIS! :pout:
    I do need to still re-torque everything. May try that tonight.
    I like em. yeah everything was stock prior. I should have done before and after Dyno runs to see the actual numbers. they feel like they gave me a little more top end.. or its the headers in combination with the new piping.
  13. Sep 11, 2014 at 12:10 PM
    #3153
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you did it on jack stands, then loosen the hardware with the truck as is. Then re-torque it. That applies to the leaf springs. I always tighten my u-bolts with the suspension hanging.
    That way if anything was in a bind, if will free it up.
  14. Sep 11, 2014 at 1:13 PM
    #3154
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    got ya. ill do that tonight. i wont jack up anything, ill just re-torque it all.
    I ran home on my hour lunch and tried adjusting my driver side coilover for the lean. its not budging... and i dont want to jump a thread again. so i took everything apart real quick, threw on a 1/4" top plate, and buttoned it all back up, and made it back to work in time. fastest ive done it yet. lol
    now.. this is just temporary unless im ok leaving it in there. I just wanted to see how the ride would be with adding more preload to that side. havent measured yet.. but till today after work at the gas station.
    also.. the rear end is "bouncy" like if i didnt have any rear shocks. i come to a stop and it bounces a little. is that the new leaf pack still "new"? or is it because i have a tire and my old leaf springs back there..
  15. Sep 11, 2014 at 1:43 PM
    #3155
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just to be doubly clear. Make sure to loosen first. Then re-torque.
  16. Sep 11, 2014 at 1:43 PM
    #3156
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    got it :thumbsup:
  17. Sep 11, 2014 at 5:48 PM
    #3157
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    so the top plate didnt do shit. im starting to think there is something else going on.. I swapped coils on my OME's.. nothing. added top plates.. nothing. bought all new suspension components.. Kings front and rear, Toytec 2" leafpack (comparable to the Dakars but only 2" of lift vs 3").. had the same taco lean..a noticeable full inch.. atleast! came home and put the top plate in on the driver side.. just went to the gas station to measure it.. yup. still a full inch lower on the driver side.. so the extra cranks i did on the driver, plus the top plate.. did nothing??
    not to mention the trucks drives like crap.. ill chalk that up to needing an alignment.. so ill hold off for now.. but as of now.. it clunks, is stiff, the rear end feels like crap. doesnt absorb crap. intersections are terrible and the rear bucks like crazy.. plus.. when i come to a stop.. it either rocks back and forth, or bounces up an down as if i i didnt have shocks at all.. that is new and i have no idea what thats about.. the truck in general is just pissing me off.. giving it till next week to let things settle more, and get my alignment.. if not.. there will be lots of parts and other shit for sale...
    ^^ not happy.. i just cant catch a break. i take one step forward and 3 steps back everytime..
  18. Sep 11, 2014 at 6:23 PM
    #3158
    JerryTaco
    JerryTaco Well-Known Member
    I'm sorry to hear all this man. If you need help sorting through all of this I am always happy to lend a hand.
  19. Sep 11, 2014 at 6:24 PM
    #3159
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    You should just take all of the new parts off and give them to me. You can have my stock suspension. Problem solved.
  20. Sep 11, 2014 at 6:29 PM
    #3160
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I just feel like i cant win.. as gay as that sounds.. im hoping a good ol' alignment will help.. and possible tweaking a few things.
    hahaha.. naaaaahhh :p
