XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Sep 11, 2014 at 6:32 PM
    #3161
    JerryTaco
    JerryTaco Well-Known Member
    Try not to get too discouraged. Sometimes these things just take a little tweaking and maybe a fresh set of eyes. You've bought the right parts, so I'm sure everything will come together
  2. Sep 11, 2014 at 9:18 PM
    #3162
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah I re-torqued everything tonight. Alignment tomorrow. I'm gonna try crankin the driver side more as well.
  3. Sep 11, 2014 at 9:22 PM
    #3163
    JerryTaco
    I saw in the mid travel thread that someone mentioned the body mount bushings. I was actually going to mention the same thing. Could account for the clunk and the lean. Try measuring from the bottom of the frame rail to the ground on both sides. Quick way to determine if it is the body mounts. Always happy to help if you want
  4. Sep 11, 2014 at 9:36 PM
    #3164
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah I actually torqued them down tonight before I even saw that post. Lol.
    It might have helped. We will see. And thanks man! Ill try measuring from the frame tomorrow.
  5. Sep 11, 2014 at 9:41 PM
    #3165
    JerryTaco
    Oh good. If the bushings are worn out it could be contributing to the lean. I'm hoping that it's something simple
  6. Sep 11, 2014 at 9:52 PM
    #3166
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I don't even know how to diagnose a worm out body mount bushing. I can't imagine it having issues already.
  7. Sep 11, 2014 at 9:58 PM
    #3167
    JerryTaco
    You'd be surprised. And it's a wear item afterall. May not be the issue but sometimes these things can be just that simple. You can measure the bushings on both sides just to compare. As for the harsh ride, that can be a number of things and hard to diagnose without riding in the truck. I'm actually dealing with some ride issues myself. I feel like my front rides better than the rear end of my truck. As of right now, I am thinking that since my front has the cdc valve set to the softest setting, and my rear end doesn't have the cdc at all, I am getting a much stiffer ride in the back which is cause the whole truck to behave a little weird
  8. Sep 12, 2014 at 7:10 AM
    #3168
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I honestly don't see how his body mounts would be worn out. If mine aren't, there's really no way in hell his are unless they're defective from the start.
  9. Sep 12, 2014 at 7:45 AM
    #3169
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have a dyno posted with just the URD Spec-U headers. Last page in my link I believe.
  10. Sep 12, 2014 at 7:49 AM
    #3170
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    When you loosened off of the bolts at the leaf spring perches and shackles, did any of them make any popping noises? That is the audible indicator that things were in a bind.
    Are the rear shocks not adjustable, as far as dampening and rebound?
    Just upgrade to new Energy Suspension bushings. ;)
  11. Sep 12, 2014 at 8:32 AM
    #3171
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    hmmm.. so looks like i would be lucky to break 300 with all my addditions huh? I still need to get the MAF CAL and have it mapped for all the bolt ons.
    ya know what.. i totally forgot to loosen everything while on the ground. I'll try it again tonight. I did tighten everything tho.
    ummm.. im sure the valving can be changed.. but as far as on the fly.. no they arent. Idk what the deal is with the rear.. having that no shock feeling and bouncing. I've never experienced that before.
  12. Sep 12, 2014 at 8:34 AM
    #3172
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Have them checked for N2 pressure, maybe the shocks aren't charged all around and that's why it's not feeling right?
  13. Sep 12, 2014 at 8:42 AM
    #3173
    Aw9d
    Aw9d That one guy
    I got no lean :)
    It's weird that you still have issues with the lean. You can try my sway bar this weekend if you want.
  14. Sep 12, 2014 at 8:42 AM
    #3174
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    it would make sense of the feeling of "no shocks"
    could it be just that the leafs are new?
  15. Sep 12, 2014 at 8:43 AM
    #3175
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    told you i wont be here. :p
    im just gonna try cranking the driver side more..
  16. Sep 12, 2014 at 8:45 AM
    #3176
    Aw9d
    Aw9d That one guy
    Figured you can take it tonight but ho-kay.
  17. Sep 12, 2014 at 8:52 AM
    #3177
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ehh maybe if i get around to it. gotta get some other stuff done first. pack and get the truck ready for Sedona.
  18. Sep 12, 2014 at 11:35 AM
    #3178
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Are you with the 8 psi pulley? I'd think you'd be around 315whp if so.
  19. Sep 12, 2014 at 11:39 AM
    #3179
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Info on these bushings??
  20. Sep 12, 2014 at 11:44 AM
    #3180
    Aw9d
    Aw9d That one guy
