XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Sep 12, 2014 at 12:04 PM
    #3181
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Sep 12, 2014 at 12:17 PM
    #3182
    Aw9d
    Aw9d That one guy
    There is even more parts. This just covers the majority of the rubber under the truck.
    That kit I posted was for a first gen. Here is the kit for Josh's truck. And still there is a lot more you can buy for the truck, look at all the NO's that this kid doesn't even cover.
    http://www.summitracing.com/parts/ens-2-18108r/applications
    Front Control Arm Bushings Included:Yes
    Rear Control Arm Bushings Included:Yes
    Front Sway Bar Bushings Included:Yes
    Front Sway Bar Bushings Greasable:No
    Rear Sway Bar Bushings Included:Yes
    Rear Sway Bar Bushings Greasable:No
    Front Sway Bar End Links Included:No
    Rear Sway Bar End Links Included:No
    Steering Rack Bushings Included:No
    Body Mounts Included:Yes
    Radius Arm Bushings Included:No
    Front Strut Rod Bushings Included:No
    Rear Strut Rod Bushings Included:No
    C-Bushings Included:No
    Axle Pivot Bushings Included:No
    Front Track Arm Bushings Included:Yes
    Rear Track Arm Bushings Included:Yes
    Front Coil Spring Isolators Included:No
    Rear Coil Spring Isolators Included:No
    Front Leaf Spring Bushings Included:No
    Rear Leaf Spring Bushings Included:No
    Front Leaf Spring Shackle Bushing Included:No
    Rear Leaf Spring Shackle Bushings Included:No
    Transmission Shift Stabilizers Included:No
    Transmission Mount Included:No
    Transmission Crossmember to Frame Bushing Included:No
    Rear Trailing Arm Bushings Included:No
    Torque Arm Mounts Included:No
    Strut Tower Bushings Included:No
    Rear Panhard Bar Bushings Included:No
    Rear Leaf Spring Pads Included:No
    Rear Spring Cushions Included:No
    Front Shock Bushings Included:No
    Rear Shock Bushings Included:No
    Rear Subframe Bushings Included:No
    Differential Pinion Bushings Included:No
    Rear Differential Carrier Bushings Included:No
    Ball Joint Dust Boots Included:No
    Tie Rod End Dust Boots Included:No
    Steering Coupler Bushings Included:No
    Rear Overload Spring Snubbers Included:No
    Rear Watts Link Bushings Included:No
    Front Axle Bump Stops Included:No
    Transmission Torque Arm Bushings Included:No
    Motor Mounts Included:No
    Bar End Grommets Included:No
    Lower Control Arm Bump Stops Included:No
    Front Bump Stops Included:Yes
    Rear Bump Stops Included:Yes
    Power Steering Ram Bushings Included:No
    Differential Carrier Mustache Bar Bushing Included:No
  3. Sep 12, 2014 at 1:40 PM
    #3183
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i DO have the pulley.. you think so huh.. with all the other stuff i have as well? what are all the benefits of getting the MAF CAL now that im done with all the performance bolt ons?
    nice!
    i shall keep this handy.. thanks
  4. Sep 14, 2014 at 6:48 PM
    #3184
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    got the truck all presentable then got it dirty the next day up at the Off Camber event (replacement for Sedonafest) was a great time as expected. those guys never disappoint.
    sure cleans up nice..
    and the event.. got a video as well.. I'll see if i can get that uploaded soon.
    Jake and I (2 of the only 4 or 5 Tacos there. But we get the same love as everyone else :) )
  5. Sep 14, 2014 at 6:58 PM
    #3185
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    :thumbsup:
    One day we will go camping together again!!
  6. Sep 14, 2014 at 7:16 PM
    #3186
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah we will! you gotta make it out next year man. even tho we didnt do any trails, it was nice to just get out, camp, relax, have some beers by the fire and see some of he FJ guys again.
  7. Sep 14, 2014 at 8:10 PM
    #3187
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Good times man. Good times
  8. Sep 14, 2014 at 9:50 PM
    #3188
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    agreed brotha man! :cheers:
  9. Sep 15, 2014 at 3:15 PM
    #3189
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Good times indeed!
  10. Sep 15, 2014 at 3:33 PM
    #3190
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Welcome to your new favorite truck picture.
  11. Sep 15, 2014 at 3:38 PM
    #3191
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    :popcorn:
  12. Sep 15, 2014 at 6:05 PM
    #3192
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    It did come out?! That's awesome! It is definitely my new fave! You always get good pics of my truck. Last one was at Sedonafest off hot loop. ;)
  13. Sep 16, 2014 at 10:41 AM
    #3193
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Awesome picture! :bowdown:
  14. Sep 16, 2014 at 1:37 PM
    #3194
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks buddy! :cheers:
    that was allll Jake.. or possibly his better half. lol
  15. Sep 16, 2014 at 1:46 PM
    #3195
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    That one was me :p
  16. Sep 16, 2014 at 1:57 PM
    #3196
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    What in the world is on your tires :eek: Is that dirt:eek::p:p
    Nice pics. Looks like a great time.
  17. Sep 16, 2014 at 5:31 PM
    #3197
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    came home and washed it IMMEDIATELY!!! :p
  18. Sep 17, 2014 at 11:57 PM
    #3198
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    You know what I love about your truck? You use it like a truck!...:D And it's clean when it's back at the nest...:D Great job bro!
  19. Sep 18, 2014 at 7:13 AM
    #3199
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey thanks man! :cheers: I try to balance that fine line of enjoying it wheeling, and enjoying it as a daily driver. Its not easy. Lol.
  20. Sep 18, 2014 at 10:26 AM
    #3200
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Awesome photographer. :bowdown:
