XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Sep 24, 2014 at 1:57 PM
    #3261
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    Hmm well Idk anything about the higher percentage stuff my tint guy is really good though so I can give you his information if you want it
  2. Sep 24, 2014 at 2:07 PM
    #3262
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Jawsh............. do u have the factory privacy glass already?
    If so, try a 20% on top of that, will equal about to 5% (but), only 35% in the front, or 30%...... just so its still easy to see ur mirrors.
  3. Sep 24, 2014 at 2:17 PM
    #3263
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Brawk.. :D yes i do. will all the windows be close to matching with that?
  4. Sep 24, 2014 at 2:20 PM
    #3264
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    no, not from inside.......but from outside YES...........since u have many windows in the back, the less light coming in thru them, the darker the front windows look (FROM OUTSIDE), yet it allows u to use ur mirrors at night easier.
    Hope that makes sense
  5. Sep 24, 2014 at 2:24 PM
    #3265
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    absolutely does. I actually really like that idea.. its perfect. can still see out the front 2, but from outside appears to all be the same. love it! :thumbsup:
  6. Sep 24, 2014 at 2:27 PM
    #3266
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    look at my truck
  7. Sep 24, 2014 at 2:29 PM
    #3267
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    FAcing the sun and its not too bad
    side to the sun (most common) and easiest for ppl to see in normally
  8. Sep 24, 2014 at 2:31 PM
    #3268
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    sun coming in from side
  9. Sep 24, 2014 at 2:32 PM
    #3269
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    like it. :) wouldnt mind the fronts a LITTLE darker.. and maybe the rears not so dark. although.. pics are hard to judge.
  10. Sep 24, 2014 at 2:33 PM
    #3270
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    much depends on the angle of the sun too. thats why I used a few diff pics.
    Films a unique toy
  11. Sep 24, 2014 at 4:33 PM
    #3271
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    true true.. ill get it figured out. have a rough idea atleast now. thanks!
  12. Sep 25, 2014 at 1:49 PM
    #3272
    Aw9d
    Aw9d That one guy
    Just plastidip your windows you puss!
  13. Sep 25, 2014 at 1:56 PM
    #3273
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Seems legit.
  14. Sep 25, 2014 at 2:23 PM
    #3274
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I kinda wanna do my rear windows for the lulz now
  15. Sep 25, 2014 at 2:24 PM
    #3275
    Aw9d
    Aw9d That one guy
    Do it! I got a pressure washer so getting it off the glass will take seconds!
  16. Sep 25, 2014 at 3:28 PM
    #3276
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i have extra cans of white plastidip....
  17. Sep 25, 2014 at 3:34 PM
    #3277
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    and octane boost
  18. Sep 25, 2014 at 3:50 PM
    #3278
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i need to try that.. that and fuel system cleaner.. does that shit really work?
    was thinking about doin some of those, and cleaning my MAF, but after reading some posts.. better leave my MAF alone. the TB tho probably could use a good cleaning. same with the rest of the truck, especially the interior.. shampoo and steam cleaning
  19. Sep 25, 2014 at 3:53 PM
    #3279
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I just steam cleaned her after getting stuck in the rain on a fucking land slide.
    I clean my MAF sensor as often as the throttle body
    I was joking about the octane boost............ a full bottle only raises shit like .6 of a point anyhow
    I run fuel system cleaner once every oil change roughly (techron)....Than again I only run chevron, mobil, shell, texaco (or if I could find 1, sunoco)
  20. Sep 25, 2014 at 4:52 PM
    #3280
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I've cleaned my MAF with MAF cleaner a few times... it even says "DO NOT USE ON TOYOTA" but worked just fine. lol
