XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Aug 8, 2012 at 4:22 PM
    #321
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Already did checked lowes, home depot, etc.. no plastic/mesh/whatever bags.
    Plus, dont want to deal with sand.
    And a full size dually would definitely ride better than a taco with a 3" lift. Lol.
    I gots dis mane. I've been researching. This is perfect for my needs. Uses water. Can place them anywhere. Doesn't slosh. Doesn't slide around. Won't freeze. Only 3" tall. Can still hold cargo on top of it.
  2. Aug 8, 2012 at 4:24 PM
    #322
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
    And then technically you will have an emergency water supply when SHTF!! Good thinking! lol
  3. Aug 8, 2012 at 4:26 PM
    #323
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Water that won't freeze huh, I know what your putting in those weights :wink:
  4. Aug 8, 2012 at 4:29 PM
    #324
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    HELLS YEAH! LOL
    Hahahaha.. well they are insulated.. and won't freeze until -40.. and -40 in Arizona might as well be -583.
  5. Aug 8, 2012 at 4:42 PM
    #325
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Trade in lydia for 2 or 3 fat girls. :notsure: that's what the LT guys would suggest
  6. Aug 8, 2012 at 4:46 PM
    #326
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hahahaha.. but dont you know man? Thats why its lifted! *insert some dumb redneck quote here*
  7. Aug 8, 2012 at 6:20 PM
    #327
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah thats It. The ones I'm getting are the max pax. Two smaller ones that you put anywhere and stack. Equals 200lbs. And If it does freeze it wouldnt mess anything for me.
    Other than that was it pretty good josh?
  8. Aug 8, 2012 at 6:38 PM
    #328
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Sounds like a good test.. lol
    You think 200lbs would be good?
  9. Aug 8, 2012 at 6:39 PM
    #329
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    I don't think 200 is enough to notice a difference. thats not much weight
  10. Aug 8, 2012 at 6:44 PM
    #330
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Next one up is 300 lbs
  11. Aug 8, 2012 at 6:48 PM
    #331
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    300 might be fine or 400. idk. before you buy I would test it. Buy some bags of sand the same weight and then drive with them and return them as long as you didn't open them.
  12. Aug 8, 2012 at 6:49 PM
    #332
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    Yeah but he has a big boy truck with the v6 :p
  13. Aug 8, 2012 at 7:11 PM
    #333
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    My tire carrier and full size spare set up probably weighed 160 lbs. the carrier was super beefy. An it made no difference in my ride...
  14. Aug 8, 2012 at 7:35 PM
    #334
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    take out your overload leaf, its free and will make a difference
  15. Aug 8, 2012 at 8:24 PM
    #335
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Ehhhh, Idk. That worries me
  16. Aug 8, 2012 at 8:25 PM
    #336
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    first of all, whats the issue with your ride? is it too rough on the speedbumps or just when your going thru washboard roads?
  17. Aug 8, 2012 at 8:37 PM
    #337
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Lol. I'm lookin to soften it up, lower the rear a bit, and get better traction in the snow.
  18. Aug 8, 2012 at 8:46 PM
    #338
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    you don't need traction in snow. you are 4x4. If you want more traction in snow buy skinnier tires like snow tires :cool:
    You want these to lower the rear. :p Buy some extended Defined Shackles. they will lower the rear and flex better and respond faster.
  19. Aug 8, 2012 at 8:54 PM
    #339
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
  20. Aug 8, 2012 at 9:22 PM
    #340
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    removing the overload leaf will lower the truck but the ride will be the same. remove the Add-a-leaf that came with the procomp lift and you should be good
