XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Oct 9, 2014 at 10:15 AM
    #3401
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I've had the intermediate shaft replaced already. I'm aware of that issue. about a year or so ago. its definitely not in the steering.
    and I have already used the gopro as well. lol
    thats when i noticed the lowers werent torque'd down fully.
  2. Oct 9, 2014 at 10:16 AM
    #3402
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Oh. Haha well I'm stumped. Race truck parts make race truck noises lol
  3. Oct 9, 2014 at 10:19 AM
    #3403
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the more i hear this.. the more i think its true.. and im just gonna have to live it..
  4. Oct 9, 2014 at 10:44 AM
    #3404
    JerryTaco
    JerryTaco Well-Known Member
    I get a little click from the front end when I just start moving, typically backing out of the garage and then it doesn't do it again until the truck has sat for a bit.. Weird, but I've gone through everything with a fine tooth comb and the best that I can figure is that it has something to do with the heims, which actually makes a little sense
  5. Oct 9, 2014 at 10:50 AM
    #3405
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    Jon's truck does that as well. It typically happens when reversing after sitting for a while. What we've found is that there is a tiny bit of play between the brake pads and the caliper. When he reverses and apply the brakes the pads shift and make a click noise.
  6. Oct 9, 2014 at 10:51 AM
    #3406
    JerryTaco
    hmmm, thats really interesting, and actually makes a lot of sense. I really only hear the click when reversing out of the garage.. Thanks for the info.
  7. Oct 9, 2014 at 1:11 PM
    #3407
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    That's what I keep saying lolz
  8. Oct 9, 2014 at 2:21 PM
    #3408
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thats what mine does too. its not consistent.. seems like after it sits like you said..
    yeah... yeah..
    sorry that I expected coilovers as expensive as they are to be a little more "fined tuned" I guess you could say..
    Guess ill learn to live with it.. just sounds and feels like crap.. hitting the trails will be interesting.. as of now.. i feel like they wont be that great.. just loud, clunky, sloppy feeling shocks over rough terrain.. where's the "smooth" factor come in?
    and you guys all know I'm anal.. so take it with a grain of salt.
  9. Oct 9, 2014 at 2:27 PM
    #3409
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Hit the trails at speed. Then you'll see where "smooth" comes in. Kings are progressive like my Fox's were.. the faster you go the smoother it gets over the normal bumps and such. Icon's don't get as smooth with digressive, but they take the harder hits smoother. Believe it or not, they are actually pretty finally tuned from the factory with higher end components lol.
    I thought hte same thing after awhile until I drove an OME truck, and was like man this thing is smoother than mine. Then I went back to mine and was like.. oh never mind, at speed there's no way in hell the OME would have kept up as smooth. It won't feel like a merc, but they're doing the job well.
  10. Oct 9, 2014 at 2:31 PM
    #3410
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Also keep in mind... by adding the pre-load you're making them ride incredibly stiff compared to out of the box. If you crank them back to zero load then go for a ride... it'll feel like butter.
  11. Oct 9, 2014 at 2:35 PM
    #3411
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I gt what you're saying. it makes sense.. i guess im just used to my OME stuff.. and it was smooth on the road.. off road was "ok".. im sure the Kings are the opposite.. "ok" on road.. and better off road. just gotta get used to them I guess.. thanks man.
    the rear needs to settle some more as well. end of October will be about 2 months.. and ive had weight back there the whole time.
    hoping they settle more as i still have rake, and im pretty sure im over 3" of lift up front.. either that, or my calculations are wrong and im not at 3" yet..
    regardless, the truck is going in soon for a service and any last warranty work as my extended warranty is about up... ill have everything checked and torqued down one last time. hopefully there wont be any other issues.
    then once i get some extra spending money again down the road.. ill upgrade to TC uppers.
  12. Oct 9, 2014 at 2:36 PM
    #3412
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    oh I know that.. thats why i wont some 650# coils. yeah they are a stiffer rate, but less preload is always good. and I gotta get that 3" of lift.. :eek:
  13. Oct 9, 2014 at 2:37 PM
    #3413
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    If you want it to settle... go beat the piss out of it on the trails. Just do a 4-Peaks El Oso run at some speed and it'll settle fast. lol
  14. Oct 9, 2014 at 2:38 PM
    #3414
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    that would work too.. as of now i have about 150 lbs in the bed.
  15. Oct 9, 2014 at 8:22 PM
    #3415
    JerryTaco
    I'd like to ride in your truck to see how the kings ride in comparison to the icon's
  16. Oct 9, 2014 at 9:12 PM
    #3416
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    My buddy has Kings and they ride smooth, but he has light weight Konig Countersteers on 16's. I have Icons and they are quite nice as well, but my heavy ass 18" Monster XD's and tires don't help with the handling. But in the end...it's all good. I don't have any clicking noises though. The only sound is the UCA's when they flex up and down and it's a normal sound for those.
    18" Monster XD's: 34lbs ea.
    16" Konig Counter-steers: 18lbs ea.
  17. Oct 9, 2014 at 10:41 PM
    #3417
    Dunkoma
    Dunkoma <3
    Andrew
    Phoenix, AZ
    Tacoma TRD Sport 4x4
    Custom Avid Sliders, AFE Intake, Painted Magnaflow Exhaust, Debadge/Plastidip badges, Icon Extended Travel C/O + 2" Rear Shocks, Icon AAL, Sway Bar Delete, Bar caddy console organizer
    All sounds like the same feeling I had when I got my icons - basically agree with everything jake is saying and what you mentioned - upgraded shocks are amazing offroad, especially at some speed and rougher as a DD. Sucks about the clunks but everything else is pretty badass dude so we should defintely go out somewhere soon.
  18. Oct 9, 2014 at 10:43 PM
    #3418
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    DONT FORGET TIRE PRESSURE AND LOAD RATINGS Can have a huge effect
  19. Oct 9, 2014 at 10:58 PM
    #3419
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Have you had the nitrogen checked in it? Like everyone's said, theses off-road parts make lots of noise and while I get annoyed at my truck sounding like a beater going over speed bumps, I know what it's capable of.
    Backed mine off to 2.75" lift and they're like butter (off-road), on road they're ok. Was just blowing down lower sycamore road at 30+ (had it up to 50 at one point).......that's where they shine. Fox resi in the rear on *8 setting and didn't bottom out once.
  20. Oct 10, 2014 at 12:04 AM
    #3420
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    for sure! anytime man!
    :thumbsup:
    we definitely need to do this! good to hear you had the same issues tho.. you should drive my truck again.
    this...
    good to know.. i need to go out on the trails this weekend.. :cool:
