XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Aug 8, 2012 at 9:26 PM
    #341
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Im waiting for patrick to give a review on the defined shackles once he buys and installs them
  2. Aug 8, 2012 at 9:27 PM
    #342
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Patrick is waiting on his next paycheck :eek:
  3. Aug 8, 2012 at 10:02 PM
    #343
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Good. You can test them for me :D
  4. Aug 8, 2012 at 10:03 PM
    #344
    PLC721
    Patrick
    Chandler, Az
    donations will be accepted from all those waiting for me to test them :D
  5. Aug 8, 2012 at 10:04 PM
    #345
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    I'm willing to volunteer for the install/ take before, during and after measurements and pictures
  6. Aug 8, 2012 at 10:07 PM
    #346
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Yeah, but in the rare case he does load the bed with no over load he could break a leaf. The add a leaf idea will work
    They work good on the trucks I rode in and installed them on. Key is before you put them in is to file the burs off the mounting point from where the OEM one cuts the metal because of the groves on it and not being able to pivot
  7. Aug 8, 2012 at 10:10 PM
    #347
    PLC721
    Patrick
    Chandler, Az
    I accept :)
  8. Aug 9, 2012 at 9:17 AM
    #348
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So how will those shackles help? i read the link and stuff. it adds more articulation, etc.. but how do they do that?
    I really dont want to take out the AAL either.
    I think i might go buy 300 lbs of sand or concrete, and test that to see if it does anything. if so, return them and get the bed weights.
  9. Aug 9, 2012 at 9:18 AM
    #349
    PLC721
    Patrick
    Chandler, Az
    They acually pivot and droop unlike the stock ones. Plus they are greats able and will ride better than stock
  10. Aug 9, 2012 at 9:22 AM
    #350
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    hmmm, im just not seeing how they can improve all that. lol but ill take your word for it. maybe im looking too into it. lol
    Alex mentioned they might "lower" it too? how would that work?
    i mean, if i can accomplish all this with those shackles.. im sold! lol
  11. Aug 9, 2012 at 9:25 AM
    #351
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    The extended ones lower the rear because your shackles on 2nd gens are inverted
  12. Aug 9, 2012 at 9:27 AM
    #352
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahhh, ok.. THATs what i was trying to figure out. thanks.
    ok, so next ?: how do they make it smoother? i get the more articulation thing.
  13. Aug 9, 2012 at 9:35 AM
    #353
    PLC721
    Patrick
    Chandler, Az
    Well I'll be ordering them when we get back from Sedona so I'll show you how they work
  14. Aug 9, 2012 at 9:38 AM
    #354
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    alright. I'll help you install them so i can see. I'll probably order them after Sedona too. maybe ill just orer them at the same time and we can install them at the same time, along with my extended top plate studs. :D
  15. Aug 9, 2012 at 9:43 AM
    #355
    PLC721
    Patrick
    Chandler, Az
    Let's do it!
  16. Aug 9, 2012 at 9:44 AM
    #356
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ...contemplating... contemplating...
  17. Aug 9, 2012 at 9:45 AM
    #357
    PLC721
    Patrick
    Chandler, Az
    Better ride, lower the ride height, much better performance off road, greasable....just say'n :)
  18. Aug 9, 2012 at 9:47 AM
    #358
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah, yeah.. im probably gonna get them. i just want to know for sure it will lower the rear.. not by alot i hope. and that they will soften up the ride.
    they do that by using the different bushings right?
  19. Aug 9, 2012 at 9:48 AM
    #359
    PLC721
    Patrick
    Chandler, Az
    No they are longer therefore lowering our rears. Mike said on my all pro springs I can expect it to be roughly 3/8-1/2" lower
  20. Aug 9, 2012 at 9:51 AM
    #360
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i meant for the smoother ride. lol i get how it lowers it.. but thats perfect. those numbers are exactly what im lookin for. thanks.
