XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Mar 11, 2016 at 6:05 AM
    #5761
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    same place it was 2 weeks ago. lol
    havent even opened it yet and no time to install it and I'm also waiting until some other goodies get here as well as working on some other things.
    :wave: hey buddy thanks. it was definitely fun, kind of busy though. we want to go back and take that creek trail all the way through.
    StOrMyThEtAcO[QUOTED] likes this.
  2. Mar 15, 2016 at 4:48 PM
    #5762
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :bored:
    need to give this thing some TLC.. and throw some mods at it.
    ChadsPride likes this.
  3. Mar 15, 2016 at 4:50 PM
    #5763
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I'm in for a wrenching day whenever
    JuansTaco likes this.
  4. Mar 15, 2016 at 4:52 PM
    #5764
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    i have zero motivation most weekends. lol I NEED to get some stuff done tho.
    I'm also waiting to order some other goodies before throwing the Prinsu on. still figuring out some other little personal touches too.
  5. Mar 16, 2016 at 8:27 AM
    #5765
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  6. Mar 16, 2016 at 8:40 AM
    #5766
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Didnt you get a Prinsu?
  7. Mar 16, 2016 at 8:41 AM
    #5767
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Yes, but he only bought it to use the box as a ramp for his rc car.
  8. Mar 16, 2016 at 8:42 AM
    #5768
    2ndGenJonny
    Jon
    Gilbert, AZ
    Well lets see some jump videos already !
  9. Mar 16, 2016 at 8:43 AM
    #5769
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah..
    but this. lol
    bastard.. :p
  10. Mar 16, 2016 at 9:21 AM
    #5770
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So I've been going over options and wiring methods for a while now trying to nail down a solution for the lighting and accessories I want to do. I've been talking to a couple TW guys who make the harnesses/switch panels trying to get info.
    If I go with the standard 6 switch rocker setup:
    Half of my lighting will require 3 pole switches (on/off/on). The problem is, getting those 3 position switches wired up to work as you would want them to (with the center description lit up all the time and then the switched to accessory lit up) you need twice as many relays and even then its a partial solution. This will leave me with 3 open slots after the 3 pole lighting is done. I can use regular 2 pole switches for the remainders and they will work as they should. one will be taken up by rock lights, so then there's two open spots left.
    If I go with a SwitchPro-8:
    I will have 2 more switches, but can use them all as intended. all lights will work, etc, but have to use one switch each for the 3 pole lights, which means I will have 1 open slot after my rock lights. its smaller, has more switches allowing me to use it how it should, easy to use, mounts anywhere.
    price is going to be about the same.. Switchpro just a little more.
    rough idea..
    so either like this.. (with switches, the first 3 being 3 pole)
    or this..
    mounted in the sunglasses holder or in the center console.
  11. Mar 16, 2016 at 9:35 AM
    #5771
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    I vote Switch Pro
    2ndGenJonny and ChadsPride like this.
  12. Mar 16, 2016 at 9:37 AM
    #5772
    JerryTaco
    JerryTaco Well-Known Member
    I'm sure it's quite a bit more expensive but that S-Pod is pretty bad ass.. Otherwise I really like the switch pro
  13. Mar 16, 2016 at 9:41 AM
    #5773
    RPS1030
    RPS1030 Well-Known Member
    Which rocker switches are you looking at? OTRATTW?
  14. Mar 16, 2016 at 10:00 AM
    #5774
    RPS1030
    A SPDT Switch (On/Off/On), some jumpered wiring and a single relay each should work just fine.
  15. Mar 16, 2016 at 10:03 AM
    #5775
    2ndGenJonny
    Jon
    Gilbert, AZ
    That switch pro is clean AF
  16. Mar 16, 2016 at 10:03 AM
    #5776
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    I looked at that switch pro the other day. Pricey but super clean!!!
  17. Mar 16, 2016 at 10:09 AM
    #5777
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    forgot about the Spod.. checking it again. not sure if it will be any better tho. Ill have to read up and see if it can do what I want.
    yeah.
    yeah I know.. but there is no middle LED for the 3 pole switches. I've been talking to a guy who makes the harnesses.
  18. Mar 16, 2016 at 10:19 AM
    #5778
    JerryTaco
  19. Mar 16, 2016 at 10:20 AM
    #5779
    RPS1030
    Each LED is Independent on the SPDT switches they have.
    http://www.otrattw.com/wiring/v6d2uhnb.pdf
    So the diagram I attached would have the lower LED on with the Dash Lights (or whatever input). Upper LED would come on only when in either ON position.
    Switch centered is OFF
    Switch Down turns the light on with High Beams (or whatever input)
    Switch Up turns in ON
    Single Relay and Single Fuse per light/switch
    Illumination and Ground could be daisy chained.
  20. Mar 16, 2016 at 10:21 AM
    #5780
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah was reading on that. gonna send them an email later seeing if it can do what i want it to. just need to control 2 outputs with one switch.
