XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. May 6, 2016 at 9:13 AM
    #6181
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup ~ 2021 Lamborghini SVJ
    Driven Safely
    I think for you man you should go with the all white strips IF you want the brightness an usefulness I say go with the white strip down that would make you look like a space ship. But if you want the multi color with less outputs go RGBW if not then sell those an buy amother set of switch backs
  2. May 6, 2016 at 9:18 AM
    #6182
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    the strips are definitely brighter.. might be a bigger PITA to install tho since its one long strip ya know. those pods are just screw in and done.
    if I do the strips, I wont have enough open spots to run switchbacks on the side.
    its either RGB rock lights with a remote (so I dont use a switchpro spot) and then I can run switchbacks on the side since I will have 2 open switches.
    or..
    run the plain white strips (using a switchpro spot) and run plain white lights on the side (using a switchpro spot)
  3. May 6, 2016 at 9:19 AM
    #6183
    Aw9d
    Aw9d That one guy
    Sounds like they are taking care of you! That's always a good sign.
  4. May 6, 2016 at 9:20 AM
    #6184
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah.. just hoping it gets here in time though.
  5. May 6, 2016 at 9:20 AM
    #6185
    Milota95
    Qrampage
    B.F.E
    Driven Safely
    Then now depends on if you want switch backs on the side or not .. I don't think you needs them would look nice but not a exacto need
  6. May 6, 2016 at 9:43 AM
    #6186
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    For sure.. The only reason I was thinkin about them was that if we are cruising those tight trails, at night, with the dust.. The white will just glare off everything. Ill have amber everywhere else, so it will cut through.. But then I'd have white/glare right out the sides. But maybe its not that big of a deal? Idk. Just trying to think of everything so I only do this once.
  7. May 6, 2016 at 9:51 AM
    #6187
    4Running Daily
    4Running Daily Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    Link to where I can get one of those 40's?
  8. May 6, 2016 at 9:51 AM
    #6188
    RPS1030
    RPS1030 Well-Known Member
    The rock lights?
    I'd just do white if it is truly easier wiring wise. Mounted all the way underneath, the glare should be minimal. And not really used/useful except when going slower than "dust-making speed"
    The only white I've had issue with was where the light bar was behind the stinger (direct reflection) and kind of the rock lights by the front upper shock mounts (directly visible in a tube buggy with limited sheet metal).
  9. May 6, 2016 at 10:30 AM
    #6189
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'll text you man.
    no I meant the side lights. those being amber and white like the rest of my lighting I think would be beneficial.
    the rock lights.. yeah i think im just gonna do the strips. one down each side of the truck. I can always add a wireless pod kit later if I really want to be fancy. I just like the colors and music sync... fun for camping.
  10. May 6, 2016 at 10:39 AM
    #6190
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  11. May 6, 2016 at 10:46 AM
    #6191
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I was actually looking at those this morning. lol
    little pricey, and they dont do everything I was hoping for.
    I have (5) 16ft strips of 5630 LED (brightest/largest LED available) to run down the truck. they will be plenty bright.
    Thats the problem.. the RGB LED use the 3528 or 5050 LEDs. not as bright, but small so they can get more of them in there, to create the RGB effect.
    guess it just proves why I went with my original plan of the 5630 strips.
  12. May 6, 2016 at 10:46 AM
    #6192
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  13. May 6, 2016 at 10:47 AM
    #6193
    RPS1030
    Yeah, dual-color option would be a plus, but depends on your switch room. I would definitely keep them switched separate as much as possible, I see them being off more than on.
    Campsite great (red could be good here also), navigation/finding turnoffs great, glare while focusing forward, no Bueno.
    From MTB lights, helmet mounted is good for "light where you look", but the glare/flashback in the dust isn't good and they kill the shadows of coming bumps/hills. So I have typically run the helmet on the low output setting and the bar on high unless the dust gets real vicious.
    ChadsPride likes this.
  14. May 6, 2016 at 10:57 AM
    #6194
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    exactly. everything else on the truck has dual color option. one switch lights up the white (whether it be the pods, lightbar, etc) and another switch lights em up as amber. independently.. not on at the same time.
    so.. yeah, thats why I was thinkin white/amber for the sides as well. would be dumb to have all my forward facing lights be set to amber if we are in a dusty environment, cruising down the trial, being able to see perfectly.. only to have blinding white right out the side of the truck. amber there would be great. BUT.. that means i wouldnt have a switch available for rock lights.. UNLESS i get a set of pods.. that has a remote.
  15. May 6, 2016 at 12:32 PM
    #6195
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  16. May 6, 2016 at 12:55 PM
    #6196
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    RPS1030 and ChadsPride like this.
  17. May 6, 2016 at 3:18 PM
    #6197
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    That's pretty spiffy I like it
  18. May 6, 2016 at 3:40 PM
    #6198
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    think I might do it! its cheap.. why not. just gotta run it inside the truck.. which isnt fun for wiring, but oh well. It SHOULD work with regular LED strips (non RGB)
  19. May 6, 2016 at 5:47 PM
    #6199
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    22" or 32" dual bars for the sides? :) gonna make an offer for 2 and see if I can get a deal. lol
  20. May 6, 2016 at 6:14 PM
    #6200
    ChadsPride
    Sponsored by TacomaWorld.com
    Dude your going to cook all the insect life you roll over!!!! :rofl:
