XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Aug 1, 2016 at 5:30 PM
    #6841
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    I feel we need to do this for a Monday meet... :annoyed:
    ChadsPride likes this.
  2. Aug 1, 2016 at 5:36 PM
    #6842
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Lol burnouts are all you. Would be pretty funny putting those on the rear and having some major lean.
  3. Aug 1, 2016 at 5:44 PM
    #6843
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Would be so fun.. Lol.
  4. Aug 1, 2016 at 5:47 PM
    #6844
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    I need a bumper so I can just push the front end against a wall an smoke them till they pop
  5. Aug 2, 2016 at 1:37 PM
    #6845
    thebeeler
    thebeeler part of the problem
    Daniel
    Yuma
    Your sister
    Total Chaos, Plate bumpers, e-locker, etc
    You don't need a wall to do a burnout lol. You need better foot work! Gotta learn to push all 3 pedals at once. If my 4cyl can do it...
    Do it!
  6. Aug 2, 2016 at 1:39 PM
    #6846
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I wanted to do it to the Toyos.. but completely spaced it.
    whenever I come across some shit wheels/tires I will.. :)
  7. Aug 2, 2016 at 2:16 PM
    #6847
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    Sooo... pics?
    ChadsPride and RPS1030 like this.
  8. Aug 2, 2016 at 2:20 PM
    #6848
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    The tires look awesome buddy. Every vehicle I have ridin in with coopers has done awesome. Let me know how you like them.
  9. Aug 2, 2016 at 3:15 PM
    #6849
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you want D pics?
    thanks man. yeah I'm liking them a lot. hoping to get them out in some action in the next couple weeks.
  10. Aug 2, 2016 at 3:18 PM
    #6850
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    UPDATE:
    Tracked down a used Snout Cutter for the TRD Blower and getting a great deal on that since I only need it the once. Will be ordering the 2.7" pulley here in the next couple weeks. Then to start saving for shop and dyno time. Been talking to Speed Sports. They will be cutting the snout, swapping pulleys, and gonna do a couple runs on the dyno and make sure everything is running smoothly.. check AFR's, etc.. just a good once over to make sure everything is looking and running as best as it can. plus... will finally have numbers!!!
  11. Aug 2, 2016 at 3:59 PM
    #6851
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    ok moose 2 questions for ya. was there anything that tells you how much the cooper weighs in a 285? if (and this is for everybody) i get a toyota 17" wheel and then when i get the newtires put 1 of my old 285's on it will that work ok for a spare?
  12. Aug 2, 2016 at 4:12 PM
    #6852
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yep.. the 285/70/17 Cooper weighs in at 55lbs.
    the spare should work.. doesnt matter what the tire is, as long as its the same size.. the wheel.. shouldnt matter either, although you would have a different track width at that point.. and depending on wheel, it might not fit the spare tire. I believe you will be ok tho..
    I have a full matching spare wheel, so I dont have much input.
  13. Aug 2, 2016 at 4:24 PM
    #6853
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    i'm considering just going ahead and getting another matching wheel i'm not so much worried about the tire as it would only be used to get me to a tire store for repair. iit may seem dumb to be concerned about the weight but with the 4cyl i don't want something too heavy but a p rated tire won't do much good in rough stuff either
  14. Aug 2, 2016 at 4:28 PM
    #6854
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    Did you pick up 5 coopers?
  15. Aug 2, 2016 at 4:33 PM
    #6855
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    got ya. yeah I picked up a matching spare because well.. I wanted one.. but also to keep everything the same just in case I needed to rotate it in. The P rated would probably be best honestly.
    nah, just 4. I didnt change tire size and I still have that brand new Nitto mounted on my spare.
    which.. speaking of.. I noticed my spare tire that I shoved in the factory location, is rubbing my diff.. actually rubbing a nice shiny clean metal spot on it. so.. back to the drawing board for the spare tire.
  16. Aug 2, 2016 at 4:38 PM
    #6856
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    your saying keep yhe p rated for a spare or use them instead of a c or e rated? i wouldn't think they'd hold up well pulling a trailer or off road
  17. Aug 2, 2016 at 4:47 PM
    #6857
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    how much off-road vs on road use are you going to be doing? the weight will make that 4cyl work for sure.. a P rated you're getting a little weight savings, but still decent tread. I think they just arent 10 ply like the E rated ones.
  18. Aug 2, 2016 at 4:48 PM
    #6858
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    or.. you say Eff it.. and go big..
    thats what I would do. lol My 98 Wrangler was a 4 banger.. rockin 33x12.50s on it.. it sucked driving on the highway.. but was a beast offroad. just gotta weigh the options.
  19. Aug 2, 2016 at 4:56 PM
    #6859
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    i'd like to get into doing more off roading i've been trying to find a compromise like a c rating if that's even durable enough for offroading i know the new ridgegrappler is supposed to come out in a c. would a tall skinny tire do better with the 4 cylinder? like a 255/85/16
  20. Aug 2, 2016 at 4:57 PM
    #6860
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    less rolling mass.. im sure it would help. but, for wheeling.. idk. I still prefer a fat aired down tire..
    ChadsPride and Casper66 like this.
