XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Mar 7, 2017 at 2:00 PM
    #8141
    Hennessy
    Hennessy Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    I had to break out power tools last time to get them to shine again, if I were a smart man I would paint/powder coat them so I would not have to keep polishing them....
    ChadsPride likes this.
  2. Mar 7, 2017 at 6:11 PM
    #8142
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Josh....i think it may be my pinion bearing....
  3. Mar 8, 2017 at 5:56 AM
    #8143
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    really? :pout:
    AR15xAR10[QUOTED] and ChadsPride like this.
  4. Mar 8, 2017 at 6:43 AM
    #8144
    AR15xAR10
    It doesn't have any play when wiggling the drive shaft but i can't figure anything else that it could be. Pinion seal failed about 15k ago and was draining my diff fluid for about a week before i saw it
  5. Mar 8, 2017 at 7:08 AM
    #8145
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Shitty. Maybe then? My rear diff has been leaking for a while as well, just recently got worse too. Leaving little puddles when I park.
  6. Mar 8, 2017 at 7:53 AM
    #8146
    AR15xAR10
    Just keep it topped off.
    I literally cannot afford to rebuild the diff right now so i have no idea what is going to happen with it. Going to have a few different mechanic buddies listen to it first
    MrCrowntown and ChadsPride like this.
  7. Mar 8, 2017 at 7:54 AM
    #8147
    AR15xAR10
    The pinion seal itsel isn't bad. Unbolt the driveshaft, pull the pinion adapter, pry the seal out replace and reassemble
  8. Mar 8, 2017 at 7:59 AM
    #8148
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Mine is the rear seal. Im just gonna keep an eye on it because im hoping to re-gear around the end of the month, so I will be in there anyways, and have a new seal already.
  9. Mar 8, 2017 at 9:01 AM
    #8149
    AR15xAR10
    Guy locally has a set of chrome ones
  10. Mar 8, 2017 at 9:48 AM
    #8150
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Naaaah. I want the ones I have.. -15mm offset and 3k load rather than the 2500.
    Impossible to find though. Going with the sr8's to avoid any fitment and availability issues.
    ChadsPride and AR15xAR10[QUOTED] like this.
  11. Mar 8, 2017 at 9:49 AM
    #8151
    AR15xAR10
    Will look so titties :drool:
    I presume matte black?
  12. Mar 8, 2017 at 9:51 AM
    #8152
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah, black with maybe some accents. Not sure yet.
  13. Mar 9, 2017 at 2:29 PM
    #8153
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  14. Mar 9, 2017 at 2:40 PM
    #8154
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I wish I was on page 420....
  15. Mar 9, 2017 at 3:19 PM
    #8155
    Old School
    Old School You are ignoring covfefe by this member.
    Chronic lateness!:rofl:
  16. Mar 9, 2017 at 3:26 PM
    #8156
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Uhh fixed :spy:
  17. Mar 9, 2017 at 3:28 PM
    #8157
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
  18. Mar 9, 2017 at 3:35 PM
    #8158
    MrCrowntown
    Alyn
    Ky
    :rasta::rasta::rasta:
    Rasta mon!!!
  19. Mar 9, 2017 at 3:35 PM
    #8159
    Old School
    Seems like yesterday!
    :rasta:
    ChadsPride and XPOTRPR[OP] like this.
  20. Mar 9, 2017 at 3:36 PM
    #8160
    Old School
    Where's Josh?
    He gonna be late again!:facepalm:
    @XPOTRPR
