XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Oct 14, 2018 at 8:45 PM
    #9201
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Loving that new truck you have there, congrats!
    XPOTRPR[OP] likes this.
  2. Oct 14, 2018 at 8:48 PM
    #9202
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    hey thanks buddy! its been fun so far and definitely keeps the miles off the Taco and saves money at the pump!
  3. Oct 18, 2018 at 1:44 PM
    #9203
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey @YumaTRD
    do you happen to know or even have a air cleaner intake tube? after poking around a bit online, looks like my pickup doesnt have the tube that goes from factory air cleaner inlet.. to somewhere near the grill on the driver side.
    pic from interwebz for reference.
    mine ends right where this is circled. I dont have the tube from there to the grill to pull in fresh air.
    also, ordered OEM waterpump, fan clutch, and thermostat. doing a coolant flush and replacing it all this weekend. next up when funds recover will be a carb rebuild and tune. then header and exhaust.
  4. Oct 18, 2018 at 2:07 PM
    #9204
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    I don't have that part. I ditched it with all the additional intake hosing.
    It seems like the engine I picked up has 20R series heads, so the headers wont swap over to the 22r.
  5. Oct 18, 2018 at 2:12 PM
    #9205
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    bummer! all good tho. and figured it was a long shot since you converted.
    Been reading and watching vids on the process for the water pump. seems pretty simple!
  6. Oct 18, 2018 at 2:16 PM
    #9206
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Have you checked your timing chain?
  7. Oct 18, 2018 at 2:17 PM
    #9207
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @mechanicjon
    So the new waterpump I ordered comes with studs. so that should help tremendously vs the bolts that are in there currently. I just need the nuts, so I'll stop by Ace. researching the process for the whole thing, and seems pretty straight forward. any other pointers? going to remove the Rad after I drain it to gain more room.
  8. Oct 18, 2018 at 2:17 PM
    #9208
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    no... guess I could try and do that during this too..
  9. Oct 18, 2018 at 2:22 PM
    #9209
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You have to pull valve cover to check timing chain. If it's quite I wouldn't worry about it.
  10. Oct 18, 2018 at 2:23 PM
    #9210
    mechanicjon
    Jon
    Scottsdale Arizona
    Try to get flanged nuts.
    XPOTRPR[QUOTED][OP] likes this.
  11. Oct 18, 2018 at 2:24 PM
    #9211
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    quiet ehh.. I havent noticed anything, but I'm also not very familiar with these 22r's yet..
  12. Oct 18, 2018 at 2:24 PM
    #9212
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    will do!
  13. Oct 18, 2018 at 2:25 PM
    #9213
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hell.. maybe I'll pick up a Chiltons/Haynes manual while I'm at it. have one for the Taco..
  14. Oct 18, 2018 at 2:28 PM
    #9214
    mechanicjon
    Jon
    Scottsdale Arizona
  15. Oct 18, 2018 at 2:30 PM
    #9215
    mechanicjon
    Jon
    Scottsdale Arizona
    What year is your 2wd?
  16. Oct 18, 2018 at 2:59 PM
    #9216
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    86
  17. Oct 18, 2018 at 3:19 PM
    #9217
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I cannot for the life of me find that damn air cleaner tube. :confused:
  18. Oct 18, 2018 at 4:46 PM
    #9218
    mechanicjon
    Jon
    Scottsdale Arizona
    Picture of were it go's.
  19. Oct 18, 2018 at 8:25 PM
    #9219
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Check the last page. I posted a pic of it.
  20. Oct 21, 2018 at 6:03 AM
    #9220
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So made some progress on the minitruck yesterday. Going to finish it up today.
    Pulled the thermostat to find it was an aftermarket one with no gasket and wasn't even seated correctly. :facepalm: so I picked up a new gasket for the new t-stat and installed it. Picked up new bolts and hardware for the new water pump and installed it as well. Cleaned up a bunch of stuff and noticed they had to modify these non OEM parts quite a bit. No wonder I was having issues with the fan clutch. Bolts instead of studs, shitty thermostat, ground down BS, etc. So much better having it all back to OEM and working. Just need to finish assembling and do a flush and fill. Then time for the 4" rear block to go in!
    Heads of bolts ground down..
    Old t-stat was just using a paper gasket.. no rubber o-ring...
    New water pump with studs vs the old without..
    You can see where they cut the shaft down on the old water pump to fit the aftermarket fan clutch. The OEM fan clutch is recessed to fit over it..
    T-stat and water pump in .
    Blocks to go in after all this..
