XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Oct 24, 2018 at 4:10 PM
    #9241
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When's the turbo going on? :boink::D
    XPOTRPR[OP] and ChadsPride like this.
  2. Oct 24, 2018 at 4:45 PM
    #9242
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    uh oh. head gasket?
    thats the plan.. get em on by this weekend.
    :brianr:
    nah.. but I did already look.. lol
    I decided to do an engine swap before anything.. 1uz, 2uz, LS.. my 4.0.. idk. lol
    Torspd[QUOTED] and ChadsPride like this.
  3. Oct 24, 2018 at 7:04 PM
    #9243
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  4. Oct 25, 2018 at 9:33 AM
    #9244
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Subbed af. Beautiful truck
    ChadsPride and XPOTRPR[OP] like this.
  5. Oct 25, 2018 at 9:37 AM
    #9245
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey thanks man! :cheers:
  6. Oct 25, 2018 at 5:35 PM
    #9246
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So back to the Taco...
    ...who knows of a place that will make me a Y-pipe with no cats... lol
  7. Oct 25, 2018 at 6:37 PM
    #9247
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Come over, and I'll get you a great deal. ;) I know a guy. :welder:
  8. Oct 25, 2018 at 6:39 PM
    #9248
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    longest commute for install ever... but oh so worth it.. :rofl:
    that would be fun man! :cheers:
    ChadsPride likes this.
  9. Oct 25, 2018 at 6:39 PM
    #9249
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Oct 25, 2018 at 6:54 PM
    #9250
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Performance Muffler will
    XPOTRPR[QUOTED][OP] likes this.
  11. Oct 25, 2018 at 6:56 PM
    #9251
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I don't want to drive all the way out there.. hahaha
  12. Oct 25, 2018 at 7:01 PM
    #9252
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sounds like the cheese is worth the squeeze.
    XPOTRPR[OP] likes this.
  13. Oct 25, 2018 at 7:14 PM
    #9253
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I found a little shop down the road I'm going to try this weekend.
  14. Oct 25, 2018 at 7:16 PM
    #9254
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    side note @Torspd .. on the 86.. I'm looking to have the exhaust done too.. what are your thoughts on dual center exit? and... plain slant cut or fancy burnt.. lol I dont know if I want to go full retard. lol
    Rextinkleton93 and ChadsPride like this.
  15. Oct 25, 2018 at 7:28 PM
    #9255
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Always go full retard man
    Torspd and XPOTRPR[QUOTED][OP] like this.
  16. Oct 25, 2018 at 7:32 PM
    #9256
    Rextinkleton93
    Kyle
    Phoenix, AZ
    ypu still working on that old truck or what man?
  17. Oct 25, 2018 at 7:32 PM
    #9257
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  18. Oct 25, 2018 at 8:06 PM
    #9258
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I like the dual tip mufflers from Magnaflow. They always resonate with me. :rimshot:
  19. Oct 25, 2018 at 8:36 PM
    #9259
    ThomasMore66
    Dallas/Fort Worth & Durango
    TX2K19 road trip and Y-pipe.
  20. Oct 25, 2018 at 10:21 PM
    #9260
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you're so Punny!! lol
    like this?
    gonna post this in my other thread too..
    Not gonna lie.. I've thought about how cool it would be to cruise out there for that.. plus meeting a lot of you guys..
    Whens the dates? lol
