XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Jun 17, 2013 at 5:27 PM
    #961
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Simple and classy. :thumbsup:
  2. Jun 17, 2013 at 5:28 PM
    #962
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    How much did those guys run you with the rings if I may ask?
  3. Jun 17, 2013 at 5:33 PM
    #963
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    They were about 900-950 i think.
    Total was 1065 mounted and balanced.
    Then all the paint, the center cap material, lug nuts, material,etc added up quick. :/ lol
  4. Jun 17, 2013 at 5:43 PM
    #964
    mh.meier
    The Doctor
    Commiefornia
    Yeah, so Ill have to come up with something different in the meantime. Lockers, OBA, REgear and RTT here in the next few months, not to mention new rubber. No monies for wheels haha
  5. Jun 17, 2013 at 6:42 PM
    #965
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Wheels can easily be put aside for all that awesomeness. :thumbsup:
  6. Jun 17, 2013 at 6:45 PM
    #966
    mh.meier
    The Doctor
    Commiefornia
    That's what I was thinking
  7. Jun 18, 2013 at 10:04 AM
    #967
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Wheels look awesome! Good job man, those center caps look like they came on the wheel like that :)
  8. Jun 18, 2013 at 10:14 AM
    #968
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks!! Yeah im super happy with how they came out. Thanks again man! :thumbsup:
  9. Jun 21, 2013 at 8:29 PM
    #969
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Need to write out my plan for the next week and get it all out.. so bear with me. :D
    Big thanks to Sebastian (Cbass) for all the help and work over the past few days. :) got a new blower motor, power steering pump, intermediate shaft, basic service with a larger oil filter, engine bay detailed, ac vents cleaned and deodorized, suspension all checked and torqued while it was up in the air, and a couple other little misc things.
    Ordered my Hub Centric Rings to center the wheels on the hub. Have had some serious vibrations. After some research, found out the wheels have a 108mm hub bore and the tacoma has a 106mm. Some simple 108mm to 106mm will do the trick and take the load off the studs making them hub centric instead of lug centric.
    Going to install the rings and my new black lug nuts at the same time when they come in next week. Throw in a new cabin filter. Will add my top plate spacer, and fix my front bumper as its loose and rattles/fogs shake. Gonna dump in some Techron fuel system cleaner on my next fill up as well. Then back to Sebastian for a new belt and a final alignment to fix my clearance issues at the back of the fender.
    Lots of much needed TLC for the Taco. Feels good. :goingcrazy:
  10. Jun 27, 2013 at 8:55 PM
    #970
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    well.. thanks to Patrick and the usual "help" from Connor :p today.. my other top plate is in.. along with my hub centric rings and black lug nuts were installed.
    the truck sits level finally.. no more taco lean.. and the hub rings 100% solved my vibration issues. the truck drives like a dream now between the work Sebastian did and my new parts.. and the rings. freakin lovin my truck right now!! :goingcrazy:
  11. Jun 27, 2013 at 9:43 PM
    #971
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    thanks buddy! :cheers:
  12. Jun 27, 2013 at 9:46 PM
    #972
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    :confused:
    Oil Pan?
  13. Jun 27, 2013 at 9:47 PM
    #973
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    what the??
    maybe you did need that skid to hide your leaks.. :p seriously tho.. that sux! any ideas?
  14. Jun 27, 2013 at 9:51 PM
    #974
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
    Jeep...
  15. Jun 27, 2013 at 9:53 PM
    #975
    05Aztacoma
    05 Tacoma 4x4
    I had an 01 TJ and the only two things that didn't leak on it were the gas tank and brake system.
  16. Jun 27, 2013 at 10:16 PM
    #976
    PLC721
    Patrick
    Chandler, Az
  17. Jun 28, 2013 at 7:34 AM
    #977
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  18. Jun 28, 2013 at 8:22 AM
    #978
    PLC721
    Patrick
    Chandler, Az
    Awesome do want I couldn't believe how your truck sounded
  19. Jun 28, 2013 at 8:26 AM
    #979
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I need to finish it! Lol
  20. Jun 28, 2013 at 10:49 PM
    #980
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man!
    You could easily find out what your wheels hub bore is compared to your jeeps... and that should give you your answer. For under 25 bucks to your door.. its worth a shot.
