XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Aug 28, 2013 at 1:42 PM
    #1141
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    I have never used fiberglass before though..
  2. Aug 28, 2013 at 1:44 PM
    #1142
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I didn't even use fiberglass. :cool:
    Check out my first page. Should have a few pics of how I made it. But.. nonetheless... fiberglass really isn't difficult to use. Especially with the small area we are talking about.
  3. Aug 28, 2013 at 1:46 PM
    #1143
    JTS2016TACO
    Jamie
    Chandler, AZ
    will do thanks for the help as always :cheers:
  4. Aug 28, 2013 at 1:48 PM
    #1144
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Of course man. :thumbsup:
  5. Aug 28, 2013 at 2:03 PM
    #1145
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    how I feel
    :tinfoilhat:
  6. Aug 28, 2013 at 6:59 PM
    #1146
    Jonesn13
    Jonesn13 Nifty
    Tempe, AZ
    '16 T4R Trail Premium, 08 AC 4x4 6spd(Sold)
    Some, Suspension and stuff, tires, maybeh some armor.
    So what was up with your vibration up front?
    Just trying to make a list of thing i will most likely need to pay attention too...
    I still have that weird clunk up front when off roading, and getting some steering vibes these days.
  7. Aug 28, 2013 at 7:15 PM
    #1147
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I got some hub centric rings for my wheels a couple months ago. They fixed my vibes I was getting from my wheels being lug centric instead of hub centric. Turns out.. I lost one recently off the front left. At the dealer.. discount.. somewhere. Put one from the rear up front.. fixed. Ordered another set and will be here Friday so I can add one to the rear I borrowed. No mas vibes!!
    Gonna hit up firestone tomorrow again and see if they can dial it in even more as it pulls right.. and has some camber issues.
    Also.. finally got around to some more trimming of the fenders.. would always rub the front and rear of the front fenders when wheeling. Was even worse after the alignment since they moved the spindle forward. would rub the front just turning. So a dremel and 30 minutes later.. finally have plenty of clearance now for wheeling. :D
  8. Aug 29, 2013 at 8:09 AM
    #1148
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Keep in mind some of that pulling could be tire wear, even though they're new it doesn't take much to them slightly out of spec and need to re-wear a bit.
  9. Aug 29, 2013 at 9:02 AM
    #1149
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man. Im gonna go in today and see what they can do. I do have some positive Camber that I would like fixed and could be the cause of the wandering sensation.
  10. Aug 29, 2013 at 9:06 AM
    #1150
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  11. Aug 29, 2013 at 9:07 AM
    #1151
    JTS2016TACO
    Jamie
    Chandler, AZ
    dafuq? why is that side like that?
  12. Aug 29, 2013 at 9:09 AM
    #1152
    Manwithoutaplan
    ID
    Does the the black mesh block any of the light ??
  13. Aug 29, 2013 at 9:12 AM
    #1153
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Both sides. That's the Camber.
    Not really. I never really use em anyways.. as the retros and HIDs outshine the Hella's. Lol. But.. regardless. No.
    Im gonna be ditching the Hella's here soon since ill have a Raptor grill.. and ill go with an LED bar
  14. Aug 29, 2013 at 9:24 AM
    #1154
    Manwithoutaplan
    ID
  15. Aug 29, 2013 at 9:26 AM
    #1155
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    "PARTYTIME!"
  16. Aug 29, 2013 at 9:28 AM
    #1156
    Manwithoutaplan
    ID
    soon my friend less then 24 hours :D.
  17. Aug 29, 2013 at 9:29 AM
    #1157
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    What time you headed out?
  18. Aug 29, 2013 at 9:35 AM
    #1158
    JTS2016TACO
    Jamie
    Chandler, AZ
    Thats really rough was it bad before you got the new tires? and LED Bars for the win Im getting in on that group buy so whenever I get my grill done I can put it in.
  19. Aug 29, 2013 at 9:36 AM
    #1159
    Manwithoutaplan
    ID
    we are headed out like 3ish not soon enough cause of traffic :/.
  20. Aug 29, 2013 at 9:40 AM
    #1160
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    No, alignment was good prior.. but I also adjusted my UCAs this time around to gain some more clearance at the back of the fender.. which MIGHT be the cause of my issues. Going in today and gonna lay it all out on the table. Might just have to set them back to what they were.
    Yeah. I hear that. We wont be leaving till about that time too. :/ Gettin in around 6pm
