XPOTRPR build & BS
Discussion in '2nd Gen. Builds (2005-2015)' started by XPOTRPR, Oct 16, 2011.
  1. Sep 3, 2013 at 9:14 PM
    #1201
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Drunk ehh?
  2. Sep 3, 2013 at 9:17 PM
    #1202
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    So are we in some three way love triangle?
  3. Sep 3, 2013 at 9:21 PM
    #1203
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    YUUUUUUUUPPPP!!
  4. Sep 3, 2013 at 9:23 PM
    #1204
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh well of course. He's out of town tho. But yes... technically. 4some. Right now tho... in this thread. 3way.
  5. Sep 3, 2013 at 9:26 PM
    #1205
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Technically I'm in this thread also, but idk any of you.. :eek:
    Edit: at least I think I am._.
  6. Sep 3, 2013 at 9:26 PM
    #1206
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Stranger danger!!!! :p
  7. Sep 3, 2013 at 10:08 PM
    #1207
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Ill gladly kick myself out for you guys to have your man love
  8. Sep 3, 2013 at 10:39 PM
    #1208
    JTS2016TACO
    JTS2016TACO Well-Known Member
    Jamie
    Chandler, AZ
    2016 MGM 4x4 TRD Off Road Double Cab Short Bed
    See my build thread in my signature
    dafuq did I just read?
  9. Sep 3, 2013 at 10:47 PM
    #1209
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    They set up a 3 way that is hopefully soon to be a 4 way once Colby gets back.. That's what I got out of it
  10. Sep 4, 2013 at 6:42 AM
    #1210
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    And i. I'm left out on all the fun...
  11. Sep 4, 2013 at 7:17 AM
    #1211
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Get on in here Jake!! :D
    On a truck related note... finally got my hub ring in. Lost one somewhere. Got it on to hopefully fix my vibes. And it didn't. Still shakes like crazy between 50-70mph. I did air up the passenger front tire to compensate for the pull I had.. so maybe that might be contributing. Doubtful tho.
    Only other options I can think of are:
    U-joints
    Carrier bearing
    Wheel bearings
    Motor mounts
    Tires were just rebalanced thursday and checked out good. Any ideas? Im goin crazy here.
  12. Sep 4, 2013 at 7:20 AM
    #1212
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    U-joints you should be able to check by sight right?
  13. Sep 4, 2013 at 7:33 AM
    #1213
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Feel and sight. Yeah. Just difficult for me in an apt complex and now a broken hand. :;
  14. Sep 4, 2013 at 7:49 AM
    #1214
    PLC721
    Patrick
    Chandler, Az
    You have an 07+ so I don't think you need to worry about motor mounts
  15. Sep 4, 2013 at 7:50 AM
    #1215
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    >.> I have a 10 and pretty sure my mounts are all shot at this point lol.
    I doubt the wheel bearings would cause it... as I can barely feel a rumble with mine and they're completely shot...
  16. Sep 4, 2013 at 7:50 AM
    #1216
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    What else should I check? It used to drive smooth as hell... not anymore. Drives like shit. :mad:
  17. Sep 4, 2013 at 7:53 AM
    #1217
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Well you did just get new tires... have you road force balanced them? Also do you have the correct lugs for these wheels?
  18. Sep 4, 2013 at 8:01 AM
    #1218
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Haven't had them road forced. They said they didn't need them. They are definitely the right lugs. I made sure to get the right ones. Its pissing me off...
  19. Sep 4, 2013 at 8:07 AM
    #1219
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Of course they said that, it's a lot of work... lol.
    Also, could just be these tires are more aggressive.... I highly doubt they would be as smooth as before no matter what you do.
  20. Sep 4, 2013 at 8:13 AM
    #1220
    HamerMan
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    "If it is in the drives you will usually feel that in the seat. Is that where you feel it? They may have to place the rear drives up on jack stands and run the truck up to speed and watch the tires to see if there is any out of round. You will see the tires going up and down as they spin. You may have a hub that was machined a bit smaller and doesn't properly center the rims on it. The wheels will get bolted up slightly off center and will spin out of round and cause this. This also would explain why changing to a different set of rims and tires did not correct anything."
    I found this somewhere, maybe could help?
