XPOTRPR Minitruck (1986 Toyota Pickup)
Discussion in 'Other Builds' started by XPOTRPR, Oct 24, 2018.
  1. Apr 9, 2019 at 4:50 PM
    #701
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    #envyboner
  2. Apr 9, 2019 at 5:21 PM
    #702
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :rofl: thanks guys. :cheers:
  3. Apr 9, 2019 at 6:21 PM
    #703
    ChadsPride
    Sponsored by TacomaWorld.com
    Perty special!
  4. Apr 10, 2019 at 6:30 AM
    #704
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Just now realizing this only has the driver mirror :anonymous:
    XPOTRPR[OP] likes this.
  5. Apr 10, 2019 at 7:43 AM
    #705
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol. thanks bruhda!
    haha! yeah.. thats OEM too. took me a while to get used to it.
    ChadsPride[QUOTED] likes this.
  6. Apr 16, 2019 at 8:28 AM
    #706
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Put in some more work with @The Fluffer up at my parents manufacturing plant over the weekend. Finished up a big industrial plumbing project and used the mini to transport tools, materials, and then a new toy for me back home. Snagged an old Manual Mill for the garage. :yes:
    Had to roll the rear fenders a bit to clear on the way home..otherwise we weren't going to make it. Lol. still had a couple inches till bumps too. Stopped at my parents and rolled them with a jack handle and did the tire rolling method. Worked perfect! Now I can go lower and not worry about it. I'm going to roll the fronts as well.
    Also Installed my floormats, gettagrip shifter, and cleaned up the interior some more. It's coming along!
    IMG_20190414_101237.jpg IMG_20190414_101416.jpg IMG_20190414_110256.jpg IMG_20190414_122402.jpg IMG_20190414_122813.jpg IMG_20190415_172213.jpg IMG_20190415_172242.jpg IMG_20190415_172326.jpg IMG_20190415_174122.jpg IMG_20190415_172411.jpg
  7. Apr 16, 2019 at 11:58 AM
    #707
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Can your new shifter hold joints in it for later? Asking for a friend
  8. Apr 16, 2019 at 12:40 PM
    #708
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    no, but it will hold a bowl worth.. lol
  9. Apr 16, 2019 at 2:50 PM
    #709
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
  10. Apr 16, 2019 at 6:34 PM
    #710
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  11. Apr 16, 2019 at 9:30 PM
    #711
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Easiest run through my firewall ever.
  12. Apr 16, 2019 at 9:55 PM
    #712
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Jealous! I had to get creative.
    Man of Steel TRD likes this.
  13. Apr 16, 2019 at 10:23 PM
    #713
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Yeah? But did you have this much out of the way?!
  14. Apr 17, 2019 at 5:21 AM
    #714
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I didn't. I did pull my fender liner partially to gain access, but then I drilled a small hole in the engine bay fender to run wire though.. then down I do the firewall pretty much exactly how you did yours. Lol
  15. Apr 24, 2019 at 4:33 PM
    #715
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    picked up some High Mileage Valvoline 5w-30, a new filter, and new air filter for the truck today. Been getting a random flicker of the oil pressure light. usually only when the motor is still cold/cool.. going to drain, inspect and fill.. and go from there.
    devidstaco and Brice like this.
  16. Apr 24, 2019 at 4:37 PM
    #716
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Maybe an oil pan drop just in case? Can never be too careful with oil.
    XPOTRPR[QUOTED][OP] likes this.
  17. Apr 24, 2019 at 4:42 PM
    #717
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I was thinking about that too. But just in case, I wasn't committed on pulling it as I need to drive it this week..
    I do want to check for sludge. I'm sure its never been pulled.
    Brice[QUOTED] likes this.
  18. Apr 24, 2019 at 4:45 PM
    #718
    Brice
    Brice Turbo Member
    Brice
    Texas
    Hopefully you don't have a saabkyle situation if you're following that build.
  19. Apr 24, 2019 at 4:48 PM
    #719
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I do not. it doesnt sound good tho.. lol
  20. Apr 24, 2019 at 4:56 PM
    #720
    Brice
    Brice Turbo Member
    Brice
    Texas
