XPOTRPR mounts and accessories
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by XPOTRPR, Jul 1, 2016.
  1. Aug 10, 2016 at 4:56 PM
    #141
    cmack
    cmack Well-Known Member
    18 Burrito
    LOL everyone kicks me out
  2. Aug 11, 2016 at 9:12 AM
    #142
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Inventory update..
    Out of stock for Flat Switch Pro mounts - more coming soon
    2 Flush Switch Pro mounts left
    5 fire extinguisher mounts left.. And going fast! More coming soon.
  3. Aug 11, 2016 at 9:22 AM
    #143
    HABOOBS
    HABOOBS Well-Known Member
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Do you have plans on making more Flat Mounts?
    Do the Flush Mounts work for overhead compartments?
    Still not sure if I'm for sure pulling the trigger on Switch Pros yet but probably in the next few weeks if so.
  4. Aug 11, 2016 at 9:25 AM
    #144
    cmack
    18 Burrito
    :popcorn:
    eventually when I order a switchpro, i'll run your flush/flat mounts
  5. Aug 11, 2016 at 9:30 AM
    #145
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yep! More are on the way! Dont you worry! :) just let me know guys!
    cmack likes this.
  6. Aug 11, 2016 at 9:35 AM
    #146
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Still having trouble seeing the differences between the two mounts... Is one just for the center console and the other for overhead?
  7. Aug 11, 2016 at 10:18 AM
    #147
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    The Flush version is curved on the underside to fit the automatic center console perfectly. The Flat version is flat.. So can be used as a general mount..
  8. Aug 11, 2016 at 10:21 AM
    #148
    HABOOBS
    Bill
    Phoenix AZ
    2008 AZ-BASED DCSB
    Got cha. Thanks!
    XPOTRPR[OP] likes this.
  9. Aug 17, 2016 at 2:07 PM
    #149
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    BUMP! got another batch of 9 Fire Extinguisher Mounts about to finish up.. Inventory is building up so get em while you can!
    Acerwin likes this.
  10. Aug 17, 2016 at 2:18 PM
    #150
    Techoma
    Techoma This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    Got my 2. Thanks mang!!!!!
  11. Aug 17, 2016 at 3:10 PM
    #151
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    right on! :cheers:
    Techoma[QUOTED] likes this.
  12. Aug 24, 2016 at 11:08 PM
    #152
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    Sub'd because eventually your gonna make something cool that i want
  13. Aug 29, 2016 at 9:44 AM
    #153
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    BUMP!!
    I have a bunch of fire extinguisher mounts ready to go!
    scottalot likes this.
  14. Aug 29, 2016 at 2:24 PM
    #154
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I will only buy an extinguisher mount if you make the light bar mount.:anonymous:
    scottalot, phx13 and AZ2013 like this.
  15. Aug 29, 2016 at 2:40 PM
    #155
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    you son of a bitch... lol
  16. Sep 6, 2016 at 10:19 PM
    #156
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Idk if this has already been covered, but why not make the clock panel be able to keep the regular hazard button? Is the original one not able to separate?
  17. Sep 6, 2016 at 10:27 PM
    #157
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    I really am liking that clock/hazard panel, it's gonna be on the to do list for my truck for sure!
    scottalot and XPOTRPR[OP] like this.
  18. Sep 6, 2016 at 10:28 PM
    #158
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @phx13 That's still to be determined. Have been working with a couple people to see if there's any differences between model years, and if they are dependent on each other.
    scottalot and phx13 like this.
  19. Sep 6, 2016 at 10:54 PM
    #159
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    I looked into that when we designed it. On mine the hazard wasn't able to be separated from the unit itself.
  20. Sep 6, 2016 at 10:56 PM
    #160
    AZ2013
    Blake
    If you have any questions about it let me know. I have pics and info on my build thread. Josh did a great job making it work.
