XRunner as a project base
Discussion in 'Long Travel Suspension' started by AFZ, Jun 4, 2012.
  1. Jun 4, 2012 at 2:22 PM
    AFZ
    AFZ [OP] Well-Known Member
    IN
    4x4 AC 4.0 TRD OR
    I found an Xrunner for a helluva deal, cheaper than any 2nd Gen I've found. It has all the features I'm looking for - V6, Manual, 2WD and Access Cab.
    With that said, is the suspension or frame different from the rest of the Tacomas? I'm worried the knuckles might be different or something.
    I'm figuring this is my best bang-for-buck, I save $4,000 over a normal 2nd Gen, then I can sell the body kit, wheels and bumpers for some more cash.
    *obviously it has factory lowering springs and different shocks
  2. Jun 4, 2012 at 5:35 PM
    RMCO
    RMCO Active Member
    It's basically a slightly lowered 5-lug with a body kit. If it fits the 5-lug it fits an X-Runner.
  3. Jun 4, 2012 at 5:37 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    as anyone else will tell you if you are going to be serious about LT the less options and the less money spent on the actual truck the better. Gives you more options to make your truck the way you want it.
  4. Jun 4, 2012 at 5:41 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Some one from xru will chime but until then... The suspension is completely different than your regular tacoma.
  5. Jun 4, 2012 at 6:13 PM
    RMCO
    RMCO Active Member
    I don't think it is really all that different aside from the bilstein shocks, front springs, and different leaf pack in the rear. That and sways front and rear and the x-brace.
  6. Jun 4, 2012 at 6:14 PM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    I'm aware of the SAU and SUA issue. Don't most LT guys run SUA to prevent twisting?
    Also is it just the A-arms, springs and knuckles that are different up front, or are the frame mounts and spring perches different?
    I guess in the long run it doesn't matter to much. I know there will be a lot of fab (garage) and my other options seem to be base-ish 4-bangers which are 5-lugs as well. At least I won't have V6 envy.
  7. Jun 4, 2012 at 6:56 PM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    Was buy a dealer.
    6 lug
    5 lug
    Oh yeah, without taking the wheels off, I can't tell about the Control Arms and mounts, but it would appear the spring perch on the 5-Lug is shorter.
    Cut and Weld?
  8. Jun 4, 2012 at 7:08 PM
    AbunaiXR
    AbunaiXR Active Member
    Hawaii
    05 SWB Xrunner
    I know for the front bumper and im gonna assume the rear, if you take off the body kit pieces, there will be slots (holes) in the bumper.
    Hard to see in this picture but you should be able to get an idea.
    Dont know if you had any interest in this, but i thought it was good to know.
    As for the suspension, it uses bilstien shocks as well. I would guess the rears could be the same, but not the front.
  9. Jun 4, 2012 at 7:10 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Lol, your turning an Xr into an LT truck? Thats kinda awesome, the thoughts crossed my mind before.
    FYI, we have the 18" rims due to our bigger breaks as well, remember to factor that into any rim/wheel combo's your thinking of
  10. Jun 4, 2012 at 7:17 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what's a helluva deal? how cheap?
    if it's just a project, you would have less expense and headache buying a salvage from a junk yard and building it up...
    for a starting build, you only really need the cab and most of the front end...
    if you can get a salvage or a beater for $3,000 then drop another $7,000 to $10,000 in the build, you have a finished rig for under $15,000...
  11. Jun 4, 2012 at 7:24 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    X2
  12. Jun 4, 2012 at 7:50 PM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    I've never seen a salvage or beater.
    Helluva Deal is ~11k. Closest V6 I've seen is $18k. Prices are absolutely stupid. 2009 Base trucks going for $15k ect. :der:
    I've been back and fourth on the whole thing. Get a junker Ranger or Hilux for $3k and start fighting rust, doing engine swaps, ect ect and then stepping back going - Ya know, I wanted a 2nd Gen... and I did all this to make it "like a 2nd gen"... and now I could have just spent the extra 25 cents and had a 2nd gen.
  13. Jun 4, 2012 at 8:00 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Before i bought my truck i came across several 2nd gen salvage titles with either frame damage or flood damage for under 6k in the exact config i wanted that i paid 19,500 for. if you are going LT all the damaged items are coming out if you get pretty serious. just a suggestion because 99.9% of the LT guys will tell you if they were to do it again they would get a salvage vehicle. might be worth going to some auctions.
  14. Jun 4, 2012 at 8:18 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    You can always find a prerunner and ask if they want to swap parts
  15. Jun 4, 2012 at 8:35 PM
    RMCO
    RMCO Active Member
    I have an X-Runner outside if you want me to snap any pics to compare. I've wanted to do a mid travel setup but gave up when I couldn't find any real options for the rear.
  16. Jun 4, 2012 at 8:36 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    All the more reason to get glass fenders and plate bumper/skids.
  17. Jun 4, 2012 at 8:43 PM
    Sunner
    Sunner Well-Known Member
    It probably wouldnt be the most cost effective or effecient way to go........bad damn wouldn't it be badass to have LT Xrunner.......
    And as Tostidos said, if I could do it all again, instead of buying a V6 Access cab 4x4, I would go find a salvage Reg Cab base model and LT dafuq outta it.
  18. Jun 5, 2012 at 4:38 AM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    As luck will have it!
    A friend called me this morning and his dealership took in on trade a mint Access Cab, V6 Pre-Runner that is Navy Blue. Not sure on year but price will be favorable. I did not know the Pre-Runner could be had as an Access Cab, sweet! Downside is its automatic, but then again that is a better selection for the dunes.
    I also found a local ’05 4X4 Access Cab. It’s silver (gross), but it’s down the street.
    Now believe it or not I have been doing a lot of research both here and other sites and I’ve realized I have a flaw in my plans. I was originally looking exclusively at RWD, mainly for cost (buy + modify), simplicity and weight. However, I never considered while most run them without issue, most are also in the South West running on hard desert. I will likely be spending 80% of my time at the Dunes in soft sand.
    Should I be strongly considering a 4x4 giving my locale, or would a set of paddles cover any fears?
  19. Jun 5, 2012 at 7:24 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Get a 4x4.......you will kill yourself later if you don't.
  20. Jun 5, 2012 at 11:54 AM
    AFZ
    IN
    4x4 AC 4.0 TRD OR
    I think you are right. Weight difference is 200lbs and if it came to it, I can delete the center shafts of the axels.
    The cost of LT for a 4X4 only appear to be at max a grand more.
