Xrunner sickness
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomaxrunner, Dec 7, 2023.
  1. Dec 7, 2023 at 7:31 AM
    Tacomaxrunner
    Tacomaxrunner [OP] New Member
    Edmundo Aleman
    Tacoma xrunner
    None
    Hello fellows Tacoma drivers. I have my first Tacoma xrunner. 2014. But it’s. Sick. I’m trying to get it fix myself. According with a mechanic has a fuel pump short circuit. I checked the relay and it’s working. Butwhen he put power directly to one side of the relay. It’s working. Anyone has an idea why. If you can sharethe fuel pump diagram it’ll be nice. Thanks
  2. Dec 7, 2023 at 7:37 AM
    Waasheem
    Waasheem
    2007 xrunner
    What sickness symptom is it showing?
    Behind the passenger headlight is the fuel pump resistor. The resistor is bypassed during starting and a couple seconds after, then power goes through the resistor.
    knottyrope likes this.
  3. Dec 7, 2023 at 7:56 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Driver side headlight. :thumbsup:
