XSP-X Thread. Let's see them!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Avery, Sep 16, 2016.
  1. Feb 6, 2019 at 11:29 AM
    #61
    Avery
    Avery [OP] 2012 XSP-X Tacoma
    Avery
    Brandon, MS
    2012 XSPX Tacoma
    Cleaned mine up over the weekend :thumbsup:
  2. Feb 18, 2019 at 2:56 PM
    #62
    WesternXSP-X
    WesternXSP-X Thread Crawlin'
    Jake
    Olympia, WA
    2015 XSP-X DCSB
    Just wanted to stop by and say hey! @AugustaTaco told me about this thread - you guys got some great looking trucks! Gotta say, you guys have sold me on the TRD Pro grill mod, and given me some great ideas on other mods :)
    Here's the most recent pic of mine, covered in some recent northwest snow!
  3. Mar 23, 2019 at 4:30 PM
    #63
    HoustonFive
    HoustonFive Well-Known Member
    Houston
    Warner Robins, GA
    2013 Tacoma XSP-X
    Got her cleaned up on this beautiful Saturday in GA!
  4. Mar 23, 2019 at 5:42 PM
    #64
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    And a lift lol!
    HoustonFive[QUOTED] likes this.
  5. Mar 24, 2019 at 2:13 PM
    #65
    Avery
    Avery
    Brandon, MS
    2012 XSPX Tacoma
    After seeing all these posts, I want to lift mine. Maybe this summer.... :)
    @AugustaTaco What size lift/tires are you running?
    AugustaTaco likes this.
  6. Mar 24, 2019 at 5:13 PM
    #66
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Running 285/70r17 on fn counter steer type x wheels. Lift is like just over 2” up front and 2” in the rear. Bilstein 5100s, eibach front springs and deaver add a leaf out back. Rides great, no complaints here
    pat's taco and Avery[QUOTED][OP] like this.
  7. Apr 16, 2019 at 4:55 AM
    #67
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    The company probably put that in there because they don't know what are trucks are. The xsp-x is purely cosmetic.
    I looked into spacers for a while and even purchased a full readylift kit. Then I decided on the ProComp shocks with 2017 springs. Raised my truck up a hair over an inch and it rides amazing.
    I went this route because my shocks already had 60k and if you're doing the labor of removing the suspension you may as well upgrade. IMG_20190326_122126163.jpg
    BizzyB726 and (deleted member) like this.
  8. Jan 8, 2020 at 5:18 AM
    #68
    XSP-X Modder
    XSP-X Modder Active Member
    2015 Toyota Tacoma XSP-X Prerunner, 2wd
    MBRP S5326AL 2.5" Cat Back, Single Side Exhaust System, Toyo Open Country A/T tires
    I’m looking for 2-3in. Lift kit for my 2015 Tacoma XSP-X prerunner. Any suggestions for under $700
  9. Jan 8, 2020 at 5:33 AM
    #69
    AugustaTaco
    Josh
    Augusta, GA
    This is the lift I have with the Eibach 2.5" lift coils and the strut set to 0 lift. I have the single AAL in the rear. About 70k miles and still rides great. Marie @HeadStrong Off-Road is great to work with.
    https://www.headstrongoffroad.com/store/p452/HS_Coil/Bilstein_5100_kit.html
    I know Rough Country spacer lifts and maybe some others say that xspx models are excluded but there is no reason why they should be, the suspension is the same (normally SR5 but there are some Sport model xspx's)
  10. Jan 8, 2020 at 5:34 AM
    #70
    AugustaTaco
    Josh
    Augusta, GA
    Oh and I should add I'm actually lifted closer to 2" even with the small lift spacers because of my winch. So a heavier OME spring might be better. I basically sit at a 2" lift f/r
  11. Jan 8, 2020 at 5:37 AM
    #71
    AugustaTaco
    Josh
    Augusta, GA
    And since this thread is about showing xspx’sss
    FE6D0BC6-E63D-4BF4-A44E-26860CBCCE47.jpg 59B20AD4-57AB-47D6-BDFD-6886586136DA.jpg
    Avery[OP], bogginator and 2013XSPX like this.
  12. Jan 8, 2020 at 6:57 AM
    #72
    XSP-X Modder
  13. Jan 8, 2020 at 7:00 AM
    #73
    2013XSPX
    GA/FL Border
    2013 XSP-X
    Right now I have ProComp ProRunner SS Shocks all around with front springs from a 3rd Gen and a 1/2 inch spacer. On the rear I have stock leafs with a 1 inch block.
    I have a set of 3rd Gen rear leafs with a 1.5 Deaver AAL I am going to put on next week. Very cost effective. Rides great!
  14. Jan 8, 2020 at 7:12 AM
    #74
    XSP-X Modder
    @2013XSPX How would I go about installing that lift kit, should I buy the tools and do it in my garage or go to a shop and have it professionally installed. Would I need any new control arms, speedometer recalibration or an alignment done after the lift kit is installed?
  15. Jan 8, 2020 at 7:15 AM
    #75
    2013XSPX
    GA/FL Border
    2013 XSP-X
    It's up to you and your level of comfort. The lift I put in was simple. You have LOTS of options. The first think you should do is determine how much lift you actually want. From there you can build your kit.
  16. Jan 8, 2020 at 7:22 AM
    #76
    XSP-X Modder
    Do I need to replace the Oem coil overs if I’m installing aftermarket shocks
  17. Jan 8, 2020 at 7:26 AM
    #77
    2013XSPX
    GA/FL Border
    2013 XSP-X
    The ProComp Shocks won't give you any lift really...it's the springs that will do that. Or a spacer you install.
    I see your truck is a 2015. How many miles are on the suspension now?
  18. Jan 8, 2020 at 7:39 AM
    #78
    XSP-X Modder
    @2013XSPX the suspension is stock and my truck has 67k miles on it,
  19. Jan 8, 2020 at 7:40 AM
    #79
    2013XSPX
    GA/FL Border
    2013 XSP-X
    If you don't plan on doing serious offroading I'd say just get a spacer lift on what you have since your mileage isn't too high. ReadyLift makes a nice kit. It's a spacer lift for the front and rear. Can be done in 4-5 hours fairly easily.
  20. Jan 8, 2020 at 7:44 AM
    #80
    XSP-X Modder
    @2013XSPX i don’t know yet how much my truck can handle, I got it a month ago and it’s only 2wd. I would like to try and off-road with my buddies who’ve got 4wd but I’m new to all the modifications that are possible. I’m just looking for advice from veteran owners. Do you know how cable a prerunner is off-road?
