XSP-X Thread. Let's see them!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Avery, Sep 16, 2016.
  1. Jan 8, 2020 at 7:48 AM
    #81
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Then def go out and play! That's how you're going to learn what you'd like. Honestly I'd do a differential breather relocate first if you plan on going out near water. As for the lift you could get the spacer lift for like $300 or or you could upgrade to an actual suspension.
    Don't rush into anything. But it looks like your options are:
    Leave it alone
    Get a spacer lift
    Get a new suspension
    I am very happy with my ProComp ProRunner SS suspension with the 3rd Gen springs and a small spacer.
  2. Jan 8, 2020 at 7:50 AM
    #82
    XSP-X Modder
    XSP-X Modder Active Member
    2015 Toyota Tacoma XSP-X Prerunner, 2wd
    MBRP S5326AL 2.5" Cat Back, Single Side Exhaust System, Toyo Open Country A/T tires
    @2013XSPX how well do spacers and blocks ride?
  3. Jan 8, 2020 at 8:28 AM
    #83
    2013XSPX
    GA/FL Border
    2013 XSP-X
    I work all over the US and in my field everyone has a built truck. I ride in all my buddies. Unless you're talking about a $3000 suspension I don't see much difference in behaviors in ride quality.
    The difference comes in PERFORMANCE. Block kits will wear parts faster and if you're doing any heavy wheeling could break fast and cause a bad day.
  4. Jan 8, 2020 at 9:23 AM
    #84
    XSP-X Modder
    @2013XSPX what’s the best way to loft the rear than?
  5. Jan 8, 2020 at 9:41 AM
    #85
    2013XSPX
    GA/FL Border
    2013 XSP-X
    For the rear you can:
    Get a new leaf pack (You'll need to make sure the shocks you're running can handle the height)
    Get an ADD A LEAF (You take your leaf springs off and slide in an extra leaf to the pack then put your leafs back on)
    Put blocks below your current leaf springs
  6. Jan 8, 2020 at 10:33 AM
    #86
    XSP-X Modder
    Do you have any suggestions for either add a leaf or new leaf springs that are realitivly cheap, cheaper than the AALs
  7. Jan 8, 2020 at 10:49 AM
    #87
    2013XSPX
    GA/FL Border
    2013 XSP-X
    I found a set of 2017 leaf springs with AAL on them here on the classifieds for $100. Check Craigslist and Facebook Marketplace as well. Otherwise HeadstrongOffroad is a great place to purchase those items.
  8. Jan 8, 2020 at 10:49 AM
    #88
    XSP-X Modder
    Thank you very much , you have been a huge help.
    2013XSPX[QUOTED] likes this.
  9. Jan 8, 2020 at 12:09 PM
    #89
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Sorry, @XSP-X Modder got busy at work. But, @2013XSPX pretty much covered all the bases with you.
    Just a notation for your research...spacer lifts are HATED on this forum because "everyone is such a serious off roader" lol. I mean, I wouldn't recommend rock crawling with a spacer lift but 95% of lifted trucks on the road are running them.
    I had a spacer lift on my 2011 Dakota 2wd for 60k miles that was mostly a street driver with zero change in ride quality or any issues whatsoever. So if budget is a concern, just do that and you can always upgrade later.
    For rear lift, I have heard a lot about Tacoma leaf springs being to weak for a block. Basically the block creates a pressure point in the middle cause the U shaped arc to turn into a W. When that happens you ass end sags and there goes your lift height. So I would seriously consider an AAL if you can swing it.
    Good luck!
    Avery[OP] and 2013XSPX like this.
  10. Jan 9, 2020 at 2:15 AM
    #90
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    I’m looking for a set of the LED DTRL under the headlight. Anybody willing to sell me theirs before they sell/trade in or know of anybody who has an extra set?
  11. Jan 9, 2020 at 4:58 AM
    #91
    XSP-X Modder
    Depending on the height of the new coil springs I buy will the stocks shocks still work?
  12. Jan 9, 2020 at 6:24 AM
    #92
    AugustaTaco
    Josh
    Augusta, GA
    I don't think so, I'm pretty sure you'd need a longer shock to accommodate the longer spring.
  13. Jan 13, 2020 at 10:22 AM
    #93
    XSP-X Modder
    Brand new
    Avery[OP] and AugustaTaco like this.
  14. Jan 13, 2020 at 1:15 PM
    #94
    AugustaTaco
    Josh
    Augusta, GA
    Looks a lot like when mine was new :thumbsup:
    Very first picture I took of her
  15. Jan 13, 2020 at 1:28 PM
    #95
    BuildbyBarz
    BuildbyBarz Well-Known Member
    Johnny
    SrQ 941
    14 MGM DCSB
    Friends don’t let friends drive stock
    Did you wire up those rear pod light to your Reverse light or you have them on a switch?
  16. Jan 14, 2020 at 4:08 AM
    #96
    2013XSPX
    GA/FL Border
    2013 XSP-X
    I almost didn't recognize my own truck it has changed so much! Ha. I have my rear pods wired from the battery to the back with an anytime switch. Super easy. I use them a ton! I have a Pelfreybilt aluminum rear bumper now with Baja lights.
  17. Jan 14, 2020 at 4:30 AM
    #97
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    Did you have to use a relay or just a basics on/off?
  18. Jan 14, 2020 at 4:46 AM
    #98
    2013XSPX
    GA/FL Border
    2013 XSP-X
    I put a relay on pretty much everything.
  19. Jan 14, 2020 at 5:23 AM
    #99
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    Thanks that what I figure
  20. Jan 14, 2020 at 5:35 AM
    #100
    XSP-X Modder
    Any suggestions on off-road areas near Tampa or St. Petersburg Florida
