XTP Intake Manifold Spacer 4.0L
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by highaltitude, Oct 7, 2013.
  1. Sep 3, 2014 at 2:17 PM
    #241
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Bought and paid!
  2. Sep 3, 2014 at 2:22 PM
    #242
    highaltitude
    highaltitude [OP] Well-Known Member
    Asheville, NC
    2017 ZR2
    Cool thanks! Sent an email to your PayPal address. I will get this out hopefully tomorrow, if not then definitely Friday.
  3. Sep 5, 2014 at 5:32 PM
    #243
    Super Black Taco
    Super Black Taco Well-Known Member
    Grayson
    Redwood valley, CA
    09 TRD SPORT 4x4
    OME 885 1/4 spacers,Dakars, 3* shims,Light Racing UCA BHLM,Wicked Flow Muffler, JL sub, Alpine amp, URD Short Throw Kit, U-Bolt Flip kit, 285/70/17 hankook mt
    Bought and paid:burnrubber:
  4. Sep 9, 2014 at 8:35 PM
    #244
    Ral
    Ral Member
    Raleigh
    Norfolk
    '13 DCSB TRD OR 6SPD
    URD short shifter
    Just installed this on a 2013 DCSB OR 6MT. Install was fairly straightforward, with a few minor exception. There were some wire bundles attached to the intake plenum underneath the air box that I had to cut the attachment for, then zip-tie once installation was complete. Additionally, we seem to have an extra air pump attached to the back of the plenum and a bracket that holds two coolant lines. Both can remain intact during installation, but the rear of the plenum is a bit difficult to move around.
    I elected to remove the throttle assembly from the plenum and air box via 4 bolts instead of removing the larger hoses.
    The size sockets you will need:
    10mm for the battery terminal and most other brackets.
    12mm for the plenum brackets themselves, and the two nuts over the torx studs on the plenum.
    13mm for the supplied bolts.
    phillips head screwdriver and pliers for clamps.
    flathead for general use and wire bracket removal.
    Overall, 2012+ vehicles may take a bit longer than the initial estimate but if you're confident enough to attempt, you can figure out the challenges.
    Initial impressions are generally in line with others; noticeable torque gain at low to mid RPM. Won't knock your socks off but you will notice. Would buy again. (I only have about 10 miles since install, so the ICU will continue to work out bugs.)
  5. Sep 11, 2014 at 12:09 AM
    #245
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    One big suggestion I have.... Take time to clean the throttle body with carb cleaner or similar stuff. I also cleaned the intake manifold too.
    Needless to say, it fixed a slight drivability issue I had.
  6. Sep 14, 2014 at 6:02 PM
    #246
    Eldo
    Eldo Well-Known Member
    Calgary
    TRDoffroad Double Cab
    a few
    Just sent payment. Thanks for the quick response. Can't wait until it gets here. :cool:
  7. Sep 14, 2014 at 11:31 PM
    #247
    Jamart5
    Jamart5 HoeRunner
    Juan
    SETX
    '16 4Runner TRD
  8. Sep 15, 2014 at 6:45 AM
    #248
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    sub'd...i tow a pretty heavy trailer (prob around 4500#) from time to time and my v6 is noticeably sluggish...wondering how much this would help...also my truck is a 6sp and according to the dyno's on this product there wasn't as much HP gain which is dissappointing.
  9. Sep 15, 2014 at 6:56 AM
    #249
    highaltitude
    Asheville, NC
    2017 ZR2
    The low/mid range is where the gains primarily are achieved. This isn't a top end mod. It works well for towing, heavy equipment, larger tires etc. My truck definitely responds better and has more torque.
  10. Sep 15, 2014 at 7:20 AM
    #250
    Chris24
    Greensboro, NC
    any idea why the 6sp had such smaller gains than the auto?
  11. Sep 15, 2014 at 8:12 AM
    #251
    highaltitude
    Asheville, NC
    2017 ZR2
    Not really, though I know I've sold to both manual and auto owners all have been happy with the product and it's gains
  12. Sep 15, 2014 at 9:11 AM
    #252
    JaRobTaco
    JaRobTaco Well-Known Member
    '08 DC LB 4x4 4.0L Sport
    I did not read through this whole thread, sorry, but have these actually been dyno'd showing results back to back on the same day and dyno?
    Just curious because I have done several builds where we have tried spacers showing no improvement on the dyno or the track. I just did a build not to long ago gained a substantial amout of power and torque on a 363c.i. Dart block Mustang when I switched from a long runner efi Edelbrock intake and coverted a Super Victor carb intake to efi which is a very short runner.
    I know differ setups respond differently so I was just wondering, thanks.
  13. Sep 15, 2014 at 10:19 AM
    #253
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    pretty sure on the order page there are dyno charts of both a manual and auto doing back to back runs.
    I am still rocking mine and love it, good gains in the mid.
  14. Sep 15, 2014 at 12:28 PM
    #254
    highaltitude
    Asheville, NC
    2017 ZR2
    Yes the Dynos were done same day, both trucks, both with and without the spacer. I think it went manual without spacer, then auto with spacer, while the auto was being run we installed the spacer on the manual, when the auto finished we ran the manual with spacer, and while it was being run we uninstalled the auto, finishing the sequence with auto and no spacer.
  15. Sep 25, 2014 at 10:14 AM
    #255
    Yota64
    Yota64 Professional Threadjacker
    How long will this GB be around? Once I start work again (I am a college student) I would like to buy this but right now even though I could use the slight MPG gain on my commutes, I need to hold onto my $$$.
  16. Sep 25, 2014 at 10:20 AM
    #256
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    From a Tacoma perspective, appears that this is a perpetual GB, from mpg perspective, will take lotso time to recover the $$$ from any mpg delta
  17. Sep 25, 2014 at 10:27 AM
    #257
    Yota64
    Thanks for the input. I understand it isn't really a turnaround investment, but after searching the thread for "MPG" I read a lot of posts in which no one mentioned loss of power or MPG, a few mentioned noticeable improvement and a little more power (iffy) and one person said it was strictly a low-end RPM improvement.
    That is good for me because I never go high end (MPG enthusiast) so aftermarket parts really can't apply to me :( but once I am working my next internship this $215 will be nothing and I feel like it's worth the money. Everyone seems happy with their investment.
  18. Oct 2, 2014 at 2:55 PM
    #258
    highaltitude
    Asheville, NC
    2017 ZR2
    I have more available!
  19. Oct 18, 2014 at 8:04 PM
    #259
    highaltitude
    Asheville, NC
    2017 ZR2
    More up for grabs!
  20. Oct 19, 2014 at 5:49 AM
    #260
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    King Remote Resi Suspension - Total Chaos UCAs - Full Katzkin Leather - Leer Camper Shell - Custom Projector Halo Headlights - HID Fogs - Eagle Eye LED tail lights - Rigid Industries LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Dakar Progressive Leafs - Fuel Beast Wheels wrapped in Hankook Dynapro ATMs - 4 Tie Down Mod - Pop N Lock - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    Subbed for future purchase.
