Xtra cab Quarter Window Latch Repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by redruM69, Feb 9, 2012.
  1. Oct 23, 2012 at 9:39 AM
    #201
    redruM69
    redruM69 [OP] Well-Known Member
    JJ
    Utah
    04 SR5
    3" Leveling kit Aluminum Window Latch Pivots :)
    What happened is the aluminum arm that's connected to the truck probably got bent outwards a little while you were working on it. No need to take it back apart, just open the window, then grab that arm and give it a couple of tugs inward. Its soft aluminum and bends easily, so be careful!
    Its also possible the pivot was installed backwards.
    Let us know how it goes!
  2. Oct 24, 2012 at 10:38 AM
    #202
    danopdx
    danopdx Member
    Portland, OR
    '02 4cyl 4wd
    Just ordered a set via Ebay. Thanks for making these available!
  3. Oct 26, 2012 at 3:20 PM
    #203
    cynicalrider
    cynicalrider #NFG
    Jersey
    I too have the same issue. At first it was because I installed it backwards but now it seems it still won't lock. I'll give the tugging the arm thing a shot.
  4. Oct 29, 2012 at 11:04 AM
    #204
    danopdx
    danopdx Member
    Portland, OR
    '02 4cyl 4wd
    Parts received and installed.
    FWIW, I used a motorcycle chain breaker to extract the pins, which made it very easy, with no resulting stress on the latch arm that easily bends, nor any need to remove the latch from the window glass. For three of the four pins, I didn't even need to put a wrench to the chain tool - the pins aren't in there very tight. The pins reinstalled very easily with a pair of channel locks.
    Thanks JJ - great product and service.
  5. Oct 30, 2012 at 12:00 PM
    #205
    redruM69
    JJ
    Utah
    04 SR5
    I have a chain breaker, but never thought of that. Cool idea!
  6. Nov 27, 2012 at 6:21 PM
    #206
    redruM69
    JJ
    Utah
    04 SR5
    Hi all!
    I have increased my production on rear window pivots and just got in a new large batch! Because of this, I have lowered my prices!! Machining accuracy has also improved!
    $5.99 each, or $9.99 a pair, FREE shipping!!
    http://www.ebay.com/itm/230856459438 <--Singles
    http://www.ebay.com/itm/330799934024 <--Pair
    http://www.amazon.com/gp/product/B00877TP4K <--Amazon (I'm working on getting free shipping here)
    Spread the word, and Happy Holidays!!
  7. Nov 28, 2012 at 12:36 PM
    #207
    kmev
    kmev Well-Known Member
    2001, 2017 Tacoma SR5
    Just ordered a set, thanks!
  8. Dec 23, 2012 at 11:35 AM
    #208
    Tool Pants
    Tool Pants Active Member
    San Jose
    2001 Xtra Cab 2.4L 2wd
    Bought a pair for my recently purchased 2001. Every Xtra Cab I looked at before I bought the 2001 had broken latches.
    I did not like the idea of hitting on the black arm that is bolted to the body with a hammer and punch to remove that pin. I thought the arm was made out of plastic - but it is some sort of metal that does not stick to a magnet. I also thought of a chain breaker to push out the pins, but the only one available to me was for bicycles and it was too small.
    So I cut a nail and with a smooth jaw plier pushed the pins out far enough to remove the broken plastic dog bone. I did have to enlarge one of the holes with a 3/16" drill bit on the replacement dog bone because the latch pin was too tight for the hole. The other hole on the opposite side of the dog bone fit the pin on the black arm just fine.
    Doing it this way you do not need to remove the latch from the glass. And, since you are not hitting on the black arm it's position will not change. Both quarter windows open and close just fine.
  9. Jan 2, 2013 at 5:43 AM
    #209
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Mine have been broken for 4 years...aggrevating, thanks for the cool fix and great price.
  10. Jan 4, 2013 at 9:49 PM
    #210
    Claymore21
    Claymore21 Well-Known Member
    Tucson, Az
    02 Gold Prerunner SR5 TRD
    Deckplate mod, Mag-lite mod, white tool box, Cobra 75wxst w/K40 mag mount, Black grille, Ultra Gauge
    I just ordered a set from Amazon, free shipping!! Thanks!
  11. Jan 7, 2013 at 10:18 PM
    #211
    Hockeyman90
    Hockeyman90 Well-Known Member
    Kaleb
    Craig, Co
    2001 Gold SR5
    Custom front bumper, bed liner, 33" wrangler duratracs on 16" ATX series Mojave rims, OME 3" suspension, 882 coils, custom rear bumper
    I bought a pair and started installing them within hours. Great product:)
  12. Jan 29, 2013 at 2:54 AM
    #212
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    bumping a good thread.
  13. Jan 29, 2013 at 9:05 AM
    #213
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Good product. I saw mine were broken on the lot. I ordered these before I owned the truck.
  14. Jan 29, 2013 at 11:14 AM
    #214
    SteveT
    SteveT Well-Known Member
    Clarksville TN
    4x4/TRD
    got mine last week. install was really easy and does the job. i found spraying just a small amount of lithium grease inside the new piece holes before putting the pins back in made the install go a lot faster.
  15. Jan 30, 2013 at 12:24 PM
    #215
    MTA
    MTA New Member
    Where do I get some of these?
  16. Jan 30, 2013 at 2:02 PM
    #216
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
  17. Feb 15, 2013 at 10:55 PM
    #217
    SUPERNICK
    SUPERNICK Active Member
    Nick
    Northern California
    01 XTRA CAB TRD 4X4
    STOCK for now
    just found this thread and i NEED these! Are they still available? I checked the ebay link and its old and no longer available
  18. Feb 16, 2013 at 12:25 AM
    #218
    redruM69
    JJ
    Utah
    04 SR5
  19. Feb 16, 2013 at 6:33 AM
    #219
    toys4ever
    toys4ever Well-Known Member
    PA
    01 4x4 4-banger stick
    I just discovered mine were broke last night, thanks to my 6 year old daughter playing with the latch... Just ordered these off ebay a minute ago and cant wait to get them... little thing like that bother me, and this a is a heck of a deal.
    thanks!
  20. Feb 16, 2013 at 8:45 PM
    #220
    SUPERNICK
    Nick
    Northern California
    01 XTRA CAB TRD 4X4
    STOCK for now
    BOOM JUST BOUGHT MINE CANT WAIT TO LET THE FRESH AIR IN!
