Xtra cab Quarter Window Latch Repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by redruM69, Feb 9, 2012.
  1. Apr 22, 2012 at 4:17 PM
    #141
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    I put mine in yesterday, they work great.
  2. Apr 25, 2012 at 10:41 PM
    #142
    broken taco
    broken taco Well-Known Member
    Adam
    San Diego / Houston
    01 TRD SR5 4WD
    Trail gear 3 Link Solid Axle Swap kit, 14 " Fox coil overs with reservoirs up front, Chevy 63 leaf spring swap with ruff stuffs Chevy 63 swap kit, 14 "Fox shocks on the rear, 37" tires, Custom front bumper by Next Venture Motor Sports with a warn winch, glassworks unlimited fender flares, custom rock rails with kickups (modeled after Relentless Fab Rock sliders), rear bumper from streetacos.com (with custom rap around protection for fiberglass fenders and the hitch receiver hidden behind the license plate that is on hinges), HID off road lights on front bumper, rigid pods on rear bumper with red back lighting, high lift mounted in the bed, onboard air, Flowmaster muffler, aftermarket air intake, alarm system, Alpine Deck, Alpine amp, Alpine speakers, JL W6 12" subwoofer, JL amp.
    i got mine in the mail today. i forget when i ordered them but it wasn't more than a week ago. i got them really quick. and i switched them out at night with only the dome light. very easy.. THANK YOU
  3. Apr 26, 2012 at 2:32 PM
    #143
    Wild Card
    Wild Card Truck yeah!
    Doug
    Portland, MI
    02 TRD SR5 4x4 V6 Xtra Cab 5spd
    6" Deckplate. Trimmed TB gasket. Grey wire. Disable DRL's.
    I installed mine a couple of months ago ( I was in one of the first shipments). And I am happy to say they are still working wonderfully, seeing almost daily use and abuse by my young children in the extended cab. Thanks again!
  4. Apr 27, 2012 at 9:26 AM
    #144
    cdnmtbkr
    cdnmtbkr Active Member
    Allan
    Kamloops, BC
    '01 Taco TRD 4x4 (US model)
    Deck-plate Mod, rear window latch pin replaced, Airaid MIT, Magnaflow Cat-Back (#15811)
    I installed my last week - easy peasy to install and they work very smoothly. The Youtube video was a great help!
  5. Apr 28, 2012 at 3:11 PM
    #145
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    I recently just bought a 04 with a latch broke, the guy I bought it from actually had a completely brand new latch setup to install just never did. I was glad when I found this to know I could just pop those pins out and use the new plastic wishbone. If mine breaks I know where I am buying my replacements!
  6. Apr 28, 2012 at 7:49 PM
    #146
    redruM69
    redruM69 [OP] Well-Known Member
    JJ
    Utah
    04 SR5
    3" Leveling kit Aluminum Window Latch Pivots :)
  7. May 2, 2012 at 9:19 PM
    #147
    Bennett707
    Oregon
    Good product defiantly snug fit! Used some wd40 on the second latch, should have used it on the first one. super stoked that I won't have to be replacing these.
  8. May 2, 2012 at 10:16 PM
    #148
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    i want some how do i buy them????
  9. May 4, 2012 at 9:54 AM
    #149
    redruM69
    JJ
    Utah
    04 SR5
    Hey guys, I created a Ecrater site to purchase these. If you dont use eBay/PayPal then this is the best alternative.
    http://dasherdeals.ecrater.com
    Enter the code "tacopivot" during checkout for free shipping!!
    Thanks again guys!!
  10. May 5, 2012 at 4:49 PM
    #150
    SargeSlapnuts
    Nick
    Pooler, Ga
    so just to be clear these brackets will help with rear windos that dont wanna close all the way and work on all first gen tacos correct?
  11. May 6, 2012 at 9:50 AM
    #151
    redruM69
    JJ
    Utah
    04 SR5
    Its designed to replace the broken plastic pivot on rear side windows on ex-cabs. Not the sliding rear window.
  12. May 6, 2012 at 9:53 AM
    #152
    Madjik_Man
    Colorado Front Range
    Question:
    When you first launched you had a blurb written on your ebay page that said something to the effect of, "once I get feedback I will make any changes that need to be made."
    Have you gotten any other feedback (other than, "holy crap this is awesome!") that makes you believe you'll make changes to the design?
  13. May 6, 2012 at 8:10 PM
    #153
    redruM69
    JJ
    Utah
    04 SR5
    I've had a few people report they were a little too tight. I haven't decided to make any changes, as the majority fit perfectly. I believe the pin tolerances are a little different from truck to truck. Too tight is easily fixed by drilling. If I make the holes bigger, most people will find them too loose.
  14. May 6, 2012 at 8:12 PM
    #154
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Good call on keeping them as-is. They may have gotten a set that was out of tolerance in that production run. Plus, like you said, easy to fix.
  15. May 31, 2012 at 4:30 PM
    #155
    hschnied
    hschnied New Member
    Hank
    Prescott, AZ
    2001 Tacoma - TRD off-road
    SnugTop cap, Yakima cargo box
    I tried doing this and ran into a few stumbling blocks. I first tried it using Firefox as my (normal) browser, after entering all the pertinent data, I clicked on the 'approve' button, the screen went blank and hung there. I tried three times, with the same result. I then tried using Windows Internet Explorer. This worked better, allowing me to actually place the order, but there was no place in the process to enter the code 'tacopivot', so I ended up paying the $1.95 for shipping. No big deal, just a bit frustrating...
    Hank
  16. Jun 1, 2012 at 8:55 PM
    #156
    redruM69
    JJ
    Utah
    04 SR5
    Yea, there are some kinks on that site that I have yet to work out. Its easier to order on Amazon or eBay honestly.
    However, I saw your order request, and I adjusted it to only charge you $20 instead of $20+ shipping
    Thanks for the input!
  17. Jun 2, 2012 at 7:19 AM
    #157
    ludeaddict
    ludeaddict Member
    NorCal
    1996 Tacoma 4X4
    N/A
    I just ordered two of these. I have been looking for replacements for a while. code did not work tho.
  18. Jun 3, 2012 at 2:37 PM
    #158
    redruM69
    JJ
    Utah
    04 SR5
    If you order on the ecrater site, just let me know here after you order, and I'll charge only $20 to the card.
    eBay and Amazon are different, and I cant give discount codes there.
  19. Jun 7, 2012 at 7:52 PM
    #159
    hschnied
    hschnied New Member
    Hank
    Prescott, AZ
    I received them a few days ago, and installed them this evening. Perfect fit!
    Thank you!!! :D :thumbsup:
    Hank
  20. Jun 11, 2012 at 4:01 PM
    #160
    redruM69
    JJ
    Utah
    04 SR5
    I am now offering free shipping anywhere in the US on my pivots when purchased on eBay!
    Thanks to everyone that has purchased these!
