Xtralights a good source for aftermarket headlights?
Discussion in 'Lighting' started by bigtaco07, Nov 2, 2011.
  1. Nov 2, 2011 at 7:25 PM
    bigtaco07
    bigtaco07 [OP] Member
    nathan
    07 tacoma with 6inch lift
    6 inch procomp lift 35 inch procomp tires 4 procomp off road lights all new stero equipment
    I'm looking to replace my headlights on my 07 taco bc my father broke the plastic clip holding the spring in place and was wondering if Xtralights.com was a good place to buy OEM replacement lights. They are not stock lights but are plug and play. And how ade is it to do the HID light swap?
  2. Nov 2, 2011 at 7:29 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    this is the 411 on replacement lights for send gen tacomas. 1st in quality is going to be depot brand housing 2nd in quality will be tyc both depot and tyc are the top choices if not going with a true factory housing eagle eyes and the others suck and have artifacts that show up mostly when taking them apart to retrofit.
  3. Nov 2, 2011 at 7:31 PM
    bigtaco07
    nathan
    Thanks, got a link I can check out what's up?
  4. Nov 2, 2011 at 7:36 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    no link for this personal experience and the word of one of the best in the retrofitting world. depot or tyc check ebay out you may be able to scoop up a set of tyc's or depots for under a 150.
    i would stay away from the eagle eyes and the other brands. btw i have helped do a couple retros and done 4 myself and have had done at least 6 now lol. i have been through all the brands for the 2nd gen.
  5. Nov 2, 2011 at 7:38 PM
    bigtaco07
    nathan
    Ok thanks, I'm guessing it isn't too very difficult to do then?
  6. Nov 2, 2011 at 7:40 PM
    bigtaco07
    nathan
    Ok thanks, so is it very hard to do the swap then? And doing the HID conversion?
  7. Nov 2, 2011 at 9:51 PM
    stunt man hans
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    what are you looking to do convert to hid or a projector retrofit? converting is as easy as some zip ties and grounding a wire and changing your bulbs hence the term "plug & play"
    now some will say it's easy but, i know different retrofitting anything can be tricky but, the tacoma headlight can be very difficult to seal back up correctly plus all the other stuff that goes along with it. to do it correctly it takes time and some experience only achieved by having done one before imo. i can walk yo through any questions you have though if you decide to take this project on though :)
  8. Nov 2, 2011 at 10:36 PM
    bigtaco07
    nathan
    Basically want to get new headlights assembly's and get the hid kit to have that sleek look. Just was wondering how are it is to get everything connected and talking properly. But that will be a project in a month time, but I may have to take you up on the offer I need some help getting it all working
