ya, ya another alignment question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by callahansd, Apr 21, 2010.
  1. Apr 21, 2010 at 5:15 PM
    callahansd
    callahansd [OP] Guest
    just got new tires 33" BFG km2s and I do not want them to burn up like my last set did, i have a 3inch lift (more like 2.5) and my specs are:::::
    Camber - Left front = 0.6 Right front= 0.5
    Caster - ...not listed... (why would it not be listed?)
    Toe - Left front= 0.09 Right front= 0.11 (doesn't look good)
    Camber/rear - left= -0.5 right= -0.2
    Toe/rear - left= 0.28 right= -0.16
    thrust angle - 0.22 (??)
    what can i do to make this better / ideal
    thanks for any help!
    Yes I know there are threads that have these specs somewhere but Id like a response to my specific specs, if your upset about the repeat question why open it?
  2. Apr 21, 2010 at 5:16 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
  3. Apr 21, 2010 at 5:17 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    ^^^ what he said
  4. Apr 21, 2010 at 5:23 PM
    callahansd
    anything I could do before new UCA's are those specs going to eat my tires? I have the 17" alloy wheels if that matters
  5. Apr 21, 2010 at 5:29 PM
    RelentlessFab
    Eric
    eh, probably wont eat tires since its close, but it definitely can be made better. The Toe and camber are the wear angles for tires.
  6. Apr 21, 2010 at 5:35 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    i'm running 2.5 in of lift on stock UCAs, and my camber looks just about the same as yours. i'm at about 3000 miles on my 265/70/17 Nitto Terra Grapplers, and i can see some wear on theoutside of my front tires. nothing major, but you can tell it's not perfect. FWIW, I will be getting some new UCAs very soon.
    also, it's kind of weird that the shop didn't list your caster. makes me wonder if it is further out than they want to admit. if you get any kind of vibrations at highway speeds (anywhere from 45 to 85), that means you caster is too low. new UCAs will also take care of that.
    hope this helps,
    colin
