Yaesu FT-8900r Which antenna?
Discussion in 'Audio & Video' started by Chipskip, Mar 6, 2012.
  1. Mar 6, 2012 at 12:15 PM
    Chipskip
    Chipskip [OP] N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I am going to be getting an FT-8900r soon and have been looking at the Diamond and Coment quad band antennas. They seem long and rigid (no way to say that without it sounding dirty) at 50/51 inches and I worry about one breaking. My truck is a daily driver, but I do hit the trails as much as possible (every few months).
    If you have a FT-8900 or another HF radio with a long antenna, please let me know how you have it installed (pics) and what you think of it. What would you do differently?
    73
    N7MCS
  2. Mar 6, 2012 at 12:30 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Don't waste your money on the 8900. It only has 10 and 6m in FM. No one does 10 and 6 in FM... only SSB. Not worth the extra cost for the extra two bands in modes no one uses on those bands and those quad band antennas suck. I would get the FT8800 and a diamond NR770 Dual band. Or better yet a Kenwood TM-V71A. I dont like how the mic cable comes out of the remote head on the yaesus. that means your stuck with your mic wherever your head is mounted. The kenwood has a seperate cable for the mic so you can put the mic anywhere.
  3. Mar 6, 2012 at 12:37 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Consistent with what Seth says, I have the 8900, but only use it with the dual band 1/4 wave antenna mounted on top of my cab.
    I keep meaning to get one of those quad band antennas to keep in the bed, so I can try it out while camped out way out in the sticks. But I can't imagine rolling down the highway with that antenna attached.
  4. Mar 6, 2012 at 12:41 PM
    PreRunnerSeth
    Apex, NC
    Would be sweet if it did SSB... could get some great skip and do some long distance on the mountains.. but FM on HF bands is useless.
  5. Mar 6, 2012 at 12:44 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah. I didn't figure out the FM only thing till after I had the radio purchased and installed.
    Oh well. I spent the absolute max amount of cash I was willing to spend at the time, and wouldn't have been willing to pony up the extra cash for a multi-mode transceiver anyhow.
  6. Mar 6, 2012 at 1:07 PM
    PreRunnerSeth
    Apex, NC
    True but you could have saved money buying a dual band only.. :)
  7. Mar 6, 2012 at 3:31 PM
    Chipskip
    Chipskip [OP] N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Yes, I know the limitation of the 10m band and how dead it is right now. The sunspot cycle will be changing next year and should really open this band. There are several repeaters in Arizona that can pic it up and help bounce all over the place. If I had the funds for a FT-857D, then I would go for it, but the radio allow beats out my install budget.
    I use my HT (2m/70cm) everyday during my drive and want to expand to more bands, otherwise I would just get an antenna amplifier.
  8. Mar 6, 2012 at 4:17 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    here in SF i was listening to a ton of contest pileups up on 10. Prop was real good. Have you been up there lately?
    EDIT forgot to say when-it was over this past weekend
  9. Mar 6, 2012 at 4:45 PM
    Chipskip
    Chipskip [OP] N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    SF or 10m?
    I use to live in Petaluma and my parents are live in Alameda now.
    No, I listen to 10m when I can, but not running a rig that gets it yet. I think next year the sun cycle changes and 10m will light up all the way across the spectrum.
  10. Mar 6, 2012 at 4:49 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I meant 10 meters:) yeah there are quite a bit of contesters and just regular conversations up there daily.
  11. Mar 6, 2012 at 4:50 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Right. But you guys understand it's not just how much activity is on 10meters per-se, but using FM vs. SSB AM mode on 10meters?
    Just checking.
  12. Mar 6, 2012 at 4:56 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I have only heard FM used ther one time. Mostly usb and some gorgeous AM too.
  13. Mar 6, 2012 at 4:58 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    BTW I am an HF listener-no ticket yet. So when I refer to 10 meters as "up there" it is from MY standpoint..you guys run mainly on 2m right? So it would be "down there" for you:D
  14. Mar 7, 2012 at 6:14 AM
    Chipskip
    Chipskip [OP] N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    ok, now I am leaning towards a FT-857D. It will blow my budget, but I can use my current cheap Comet 2m/70cm magnetic antenna until I can afford to upgrade my antenna(s).
    It's all about scalability.
  15. Mar 7, 2012 at 9:15 PM
    PreRunnerSeth
    Apex, NC
    Much better choice for a mobile HF/VHF/UHF rig. You will get much more use out of HF with SSB ability. You will have to get a Screwdriver antenna though for the HF bands.
  16. Mar 8, 2012 at 8:51 AM
    Chipskip
    Chipskip [OP] N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    The 857D is going to eat my whole install budget (for now) but I already have a 2m/70 mag mount antenna for my HT. So I can get the adapter for it and I will be good for now. Then when I pass my General I can get the Yaesu ATA-120 antenna or something similar (Plenty of time to do the research on that).
    Maybe when I get my radio it will be time to start a build thread.
