yahmaha carb leak
Discussion in 'Motorcycles' started by blacksheff405, May 10, 2011.
  1. May 10, 2011 at 6:10 PM
    blacksheff405
    blacksheff405 [OP] no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    Hey i was curious if someone in her could help me with my yahmaha 125L dirtbike. it has a carb leak and i think it is the pin. its a 20mm mukini carb. and its leaking from a hose in the bottom of the carb. do i just need to clean it or what
    any help would be appreciated thanks :)
  2. May 10, 2011 at 6:22 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    get a carb kit, it will come with now o-rings or gaskets. spray the internals with carb cleaner, use a old toothbrush to scrub the guts and you should be good to go. and do not over torque the jets if you remove them... i broke a jet before. hope this helps
  3. May 10, 2011 at 7:40 PM
    blacksheff405
    caleb
    thanks man i'm not good with bikes so thanks for the help
