Yakima Permanent Landing Pad Install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmdriscoll, May 3, 2011.
  1. May 3, 2011 at 8:56 PM
    jmdriscoll
    jmdriscoll [OP] New Member
    Richmond, VA
    03 Tacoma Double Cab
    Air-box mod
    Hello, I have been reviewing rack options for my 09 Taco. I will be hauling up to 4 boats on the rack, so the stocker just won't work. I have been looking at Yakima, Thule, Rhino Rack, Inno Racks, etc. While researching the permanent tracks, I found this video on the Yakima Landing Pad install. In the video they utilize the mounting holes in the channel underneath the rubber channel strip. Although a different vehicle, I was wondering if the same could be done on the Tacoma?
    http://wn.com/Yakima_Control_Towers...r_fixed_point_attachments_by_ORS_Racks_Direct
    Thanks,
  2. Jul 19, 2011 at 5:20 PM
    musty40
    musty40 Well-Known Member
    Alan
    Duluth, MN
    2010 DC SB TRD OR
    Mike,
    Did you find a landing pad that will work?
    Alan
  3. Jul 19, 2011 at 10:18 PM
    jmdriscoll
    Richmond, VA
    Air-box mod
    Musty, I ended up going with a clip on rack. I contacted Yakima and inquired about utilizing the stock rack holes under rain gutter, and they indicated that it is possible with certain make/models of vehicles. However, the 2nd gen toyota is not one of those make/models..
    I ended up going with a rhinorack with aero bars. Good load capacity, and best bang for the buck. "Assuming that they last the test of time"
    -Mike
