Yakima Rails on Bed Rails
Discussion in '2nd Gen. Tacomas (2005-2015)' started by inlinejohn, Apr 3, 2010.
  1. Apr 3, 2010 at 5:11 PM
    inlinejohn
    inlinejohn [OP] Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    My goal is to have a cover over my truck bed (Access or Truxedo)....the type that velcros and rolls, then mount these Yakima rails to the tops of the truck sides. Anyone done this? Anyone put bolts/screws through the plastic/metal top surface of the bed? What does the metal look like under the plastic? Are there stake holes? Is there access to the underside for a nut/washer? Any additional advice/thoughts on how to achieve this. I think I'll have to space the rails up a few inches so the rolling of the cover will fit under the cross bars.
  2. Apr 3, 2010 at 7:38 PM
    Tim A
    Tim A Well-Known Member
    Montana
    2011 TRD Offroad 6 spd Double Cab
    I was just dismantling my bed rail caps today, but for a different reason. Just FYI here's something that may help you.
    To take off the bed rail caps, you have to remove the Torx (size T30) bolts located inside the C-channel rails... and the heads strip out pretty easy. I ended up having to remove a couple of the heads with a drill. Then I turned them out from the back by popping out those cubby hole boxes and reaching up into the fender. I went to the hardware store and replaced all the Torx bolts with Allen head bolts...the size is M6 x 1.00.
    After that, there's 2 hex head bolts (10mm IIRC) right next to the tailgate. Finally, there's one of those plastic rivets at each end of the bed.
    After all that hardware is removed you can pop the bed rail off and have a look under it. I think there was metal under there but I didn't take the whole thing off as I was working on the C channel rails. If you were to mount something on top of the bedrails, I think it would be possible to reach through the cubby holes and hold back on a nut with your fingers or maybe even a wrench.
    Hope that will help
  3. Apr 3, 2010 at 7:44 PM
    Tim A
    Montana
    Actually you know what I may be wrong about having to remove those Torx bolts...you may just have to remove the hex head bolts and the plastic rivets if you're just taking off the bed rail cap.
  4. Apr 4, 2010 at 7:09 AM
    inlinejohn
    Washington
    If the Yakima rail is 60" long, do you think you could reach to each end of it from the cubby hole? I'm thinkin it's too far??
  5. Apr 4, 2010 at 7:29 AM
    Tim A
    Montana
    There's the big one near the tailgate (the one w/ the door) then the little one nearest the cab...between those 2, you should be able to reach along the entire bed rail unless you've got short arms like a T-Rex.
  6. Apr 4, 2010 at 7:36 AM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    I think this is what you're looking for with the exception that its not a velcro cover, but it does roll up. The rack system is on a track like the one pictured above.
  7. Apr 4, 2010 at 5:50 PM
    Tim A
    Montana
    ^^that looks good. I'd love to see some close ups if you got em. Looks like Yakima Control Towers but I can't tell for sure.
  8. Apr 4, 2010 at 7:21 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
  9. Apr 4, 2010 at 9:29 PM
    black cx
    black cx Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    anyone got links to that yakima rail on the bed rail setup?
  10. Apr 4, 2010 at 9:48 PM
    dlthunder
    dlthunder Well-Known Member
    Dan
    Reno, NV
    Sold my Taco
    TRD Skid Plate Rear Seat 11inch DVD Toyota Bed Mat Pace Edwards Full Metal Jackrabbit Nerf Bars Tailgate Electric Dynolock D-ring Bedbolts
    Pace Edwards has a cover that includes rails for the yakima rack.
  11. Aug 23, 2010 at 10:24 AM
    18seeds
    18seeds Well-Known Member
    Here is what i did
  12. Aug 23, 2010 at 10:28 AM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    any better pics of how its mounted?
  13. Aug 23, 2010 at 10:34 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    That is exactly what I want to do with mine! I think its as simple as taking the mounts you would use for camper shells and drilling/screwing them into the caps on side of the bed. I want to be able to have my roll up tonneau cover closed and have the rack with bikes, etc. mounted above it.
  14. Aug 23, 2010 at 11:51 AM
    18seeds
