Yakima spare tire mount help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by el_turks, Feb 12, 2016.
  1. Feb 12, 2016 at 6:53 PM
    el_turks
    el_turks [OP] Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    I installed the Yakima spare tire mount on my bed rail. I was happy with it until I started driving and the tire moved from its original position. It shifted because the top section of the tire does not rest against anything and as I drive it shifts and does not return to its original position.
    Has anyone experience this and was able to resolve it?
    Installed Plate
    Leaning tire after driving
    Tire off the bed after driving.
  2. Feb 12, 2016 at 7:08 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    So it goes from resting flat to tilting? Is that what you are saying? Or is it sliding along the rail horizontally?
    I'd imagine you could just anchor the tire with one of the bottom wheel holes over to the rear bed tie down ring to keep it nice and locked in tight. Via a cable or rope or something.
  3. Feb 12, 2016 at 7:24 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Looks like a recipe for disaster if you ask me. Terrible place to mount a spare.
    Not sure what is going on with that mount either...
    I'd lay flat and strap it down, or upright next to cab so it's not a missile during a collision. :)
  4. Feb 12, 2016 at 7:49 PM
    el_turks
    Southern California
    Yes it goes from vertical to tilting. And yes, I thought about using the bottom rear bed tie down... I will be looking into that or maybe adding some bars to the mount so it stays vertical.
  5. Feb 12, 2016 at 8:21 PM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    I like it. You got a link to it.
  6. Feb 12, 2016 at 8:25 PM
    el_turks
    Southern California
  7. Feb 12, 2016 at 8:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There was someone on here that had a tire mounted that was or similar method an it caused the bed side to crack due to fatigue and flexing of the bed side.
    I would not do it.
  8. Feb 12, 2016 at 8:42 PM
    el_turks
    Southern California
    The person that
    Yes I did see that post but it was not setup the same way. He used 2 bolts and I am using a plate that spreads the weight across the rail. I just need to ensure that the tire does not move. I have seen others used this method and it does work. I just need to solve this tilting problem.
  9. Feb 12, 2016 at 8:59 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    I remember that. If I recall, it was one of MetalMillers. But his was basically a piece of square tube that also stuck out a good 2 inches and had a small base plate.
    I probably wouldn't run it attached to my rails either though. Whenever my spare is in my bed its strapped down to L-Track.
  10. Feb 12, 2016 at 9:00 PM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    I thought 285's fit in the factory carrier with little modification, why not carry it there? This looks like a recipe for disaster if you are ever rear ended.
  11. Feb 12, 2016 at 9:04 PM
    Pigpen
    Dan
    Northwest Montana
    If you (OP) are the offending rear ender (it happens), the tire will likely become a projectile.
  12. Feb 12, 2016 at 9:08 PM
    el_turks
    Southern California
    if you look at my tire, it is also tied down by a chain to the bottom strap on the truck bed. I may use a strap, if I decide to keep it there. But I like the points that you are all making. Maybe I, I should just move it to the spare tire mount on the daily drives and on the bed while off road.
  13. Feb 13, 2016 at 3:37 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    When I carry my 2nd spare, I simply place it vertically up against the front of the bed (cab) and hold it in place using 2 of the track bed cleats and a ratchet strap. It's never come loose.
  14. Feb 13, 2016 at 5:47 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    It's tilting because the whole setup is twisting your rail. There are gaps above and below the rail, behind the mounting plate, from the height of the bed rail. Put some shims behind the plate so that it can't twist.
    That plate is designed to sit on a wide flat surface, and the bed rail isn't.
  15. Feb 13, 2016 at 5:52 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Wait, isn't the Yakima Spare Tire Carrier that you linked to for mounting flat on top of a roof rack? That might be your issue.
    Also, I wouldn't suggest mounting anything heavy like a wheel and tire to your bed rails, my bedside panels have slight ripples now from mounting too heavy of shit to it.
  16. Feb 13, 2016 at 8:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Some have to find out for themselves....
  17. Feb 13, 2016 at 10:19 PM
    el_turks
    Southern California
    Working on it.
    Yes that is the issue. I need to figure out a solution that levels the plate and distributes the weight of the tire.
    some of us do, yes we do.
    Jimmyh[QUOTED] likes this.
